Replaced cooling system, still overheating - JeepForum.com
post #1 of 3 Old 12-09-2010, 03:33 PM Thread Starter
JeepRyderz
1987 XJ Cherokee
87 Wagoneer 4.0, replaced radiator, upper and lower radiator hoses, water pump, and took thermostat out and it still over heats in idle in about 5-10min. First over heated when dragging 500lb tree in reverse out in desert.
JeepRyderz is offline
post #2 of 3 Old 12-09-2010, 03:59 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
you may need to burp the system. do a search for how to properly do so. and put a thermostat back in!
1990JEEPXJ is offline
post #3 of 3 Old 12-09-2010, 04:18 PM
99xjjoe
Put the thermostat back in for sure (will over heat with out a thermostat) and is your fan clutch good also use a temp gun to check to see if you temp sensor if working
Didn't the 'check shock' light come on?
99xjjoe is offline
1987 , over heating , radiator , wagoneer
Replaced nearly entire cooling system... Kasia XJ Cherokee Technical Forum 10 04-22-2010 04:22 PM
just finished major cooling system overhaul, still overheating... in_motion XJ Cherokee Technical Forum 5 07-18-2009 08:12 PM
Is the AC system and the engine cooling system connected firedogut XJ Cherokee Technical Forum 8 07-17-2009 10:47 AM
Closed cooling system to Open system? motu1983 XJ Cherokee Technical Forum 7 08-02-2007 09:39 AM
Cooling System Problems - Overheating 95Cherokee- XJ Cherokee Technical Forum 4 02-16-2005 05:47 AM
