-   -   Replaced cooling system, still overheating (http://www.jeepforum.com/forum/f11/replaced-cooling-system-still-overheating-1139016/)
JeepRyderz 12-09-2010 03:33 PM
87 Wagoneer 4.0, replaced radiator, upper and lower radiator hoses, water pump, and took thermostat out and it still over heats in idle in about 5-10min. First over heated when dragging 500lb tree in reverse out in desert.
1990JEEPXJ 12-09-2010 03:59 PM
you may need to burp the system. do a search for how to properly do so. and put a thermostat back in!
99xjjoe 12-09-2010 04:18 PM
Put the thermostat back in for sure (will over heat with out a thermostat) and is your fan clutch good also use a temp gun to check to see if you temp sensor if working
The time now is 02:09 PM.
