Replaced Battery, Voltage at 19 and check gauge light on. - JeepForum.com
post #1 of 39 Old 12-26-2013, 05:04 PM Thread Starter
tbain235
My old battery was old, and would barely start my jeep. I went to firestone and got a new one, but after installing it there was no power. All of the connections were good, so I gave it a jump. As soon as I started driving around, the check gauges light came on and the battery voltage was maxed out at 19. I parked the car and turned it off, and the battery was dead again.
Did firestone just give me a bad battery?
tbain235 is offline
post #2 of 39 Old 12-26-2013, 05:35 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
More likely cause is that your battery or alternator wires/wire connections are loose, or corroded. The battery is fully charged, right ?
CJ7-Tim is offline
post #3 of 39 Old 12-26-2013, 06:42 PM Thread Starter
tbain235
I checked all the battery and alternator connections and they seemed fine. Could the alternator be bad?
tbain235 is offline
post #4 of 39 Old 12-26-2013, 07:05 PM
CJ7-Tim
CJ7-Tim's Avatar
The alternator and the battery can be tested to determine their condition. The wire connections "seemed fine", or you took them apart, cleaned them, and firmly reattached them ?
CJ7-Tim is offline
post #5 of 39 Old 12-26-2013, 07:21 PM Thread Starter
tbain235
Im trying to procure a voltmeter to test the battery. If not Im going to take the alternator off and bring it in to be tested, and when I do that Ill clean all the connections good.
tbain235 is offline
post #6 of 39 Old 12-27-2013, 11:19 AM
CJ7-Tim
CJ7-Tim's Avatar
Excellent plan.
CJ7-Tim is offline
post #7 of 39 Old 12-27-2013, 06:12 PM
Gcallaway
x2 check all connections on battery , that is the problem. Replace battery cables if needed.
Gcallaway is offline
post #8 of 39 Old 12-27-2013, 07:37 PM
Azzy
Cables can rot from the inside, and look fine on the outside. Test them to see if there is resistance. between teh cables, alt and battery, one bad leg of that triangle can cause the others to die in a swift manner.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #9 of 39 Old 12-27-2013, 07:52 PM
LumpyGrits
Voltage does not make the battery in this case.
Amps are where it's at
Take it back to FS, have them charge the battery and perform a 'load test'.
IMHO: Wal-Mart has better batteries.
I see your MCBH. Are you a Marine?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #10 of 39 Old 12-28-2013, 09:15 PM Thread Starter
tbain235
I brought the alternator in and it tested good. I used a wire brush on all the connections and I still didnt get anything. I tried to jump it again, to see if the voltage was really at 19+ when it was running. All that happened was I got power when the cables were connected, but when I tried to start it I lost all power and couldnt get it back. Im going to go out tomorrow and check the resistance between the cables.
And yeah you got me, Im a Marine currently stationed at MCBH haha.
tbain235 is offline
post #11 of 39 Old 12-28-2013, 10:37 PM
xjdantheman
1993 XJ Cherokee
New battery could have a internal problem if you can jumpstart it.
xjdantheman is offline
post #12 of 39 Old 12-29-2013, 09:07 AM
CJ7-Tim
CJ7-Tim's Avatar
Clicking and not starting, or a loss of power and not starting, is usually a low voltage issue from:
• leaving the lights on
• a failing battery
• a failing alternator
• dirty, corroded, or loose wire connections
• internally corroded battery wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, the ground wires at the coil, and the ground wires from the battery and engine to the Jeep's frame/body. You must remove, wire brush, and clean until shiny the cable/wire ends and whatever they bolt to.
Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Place your DVOM (Digital Volt Ohm Multi-Meter) on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp ) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then you have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+stud = 0.5 volt with maximum charging load applied (all accessories turned on)
Test the output at the alternator with your volts/ohms multi-meter. You should be measuring 13.8-14.4 volts. Load testing the alternator is still recommended.
Exchange the ASD relay with the Starter relay in the fuse box under the hood near the battery.
Have your helper turn the ignition key to START while you tap on the starter with a hammer. If the engine starts, you probably need a new starter.
Have the battery, starter, and the alternator Load Tested for proper functioning a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
CJ7-Tim is offline
post #13 of 39 Old 12-29-2013, 10:55 AM
LumpyGrits
Take the starter motor in for load/amp pull.
LG
post #14 of 39 Old 12-29-2013, 06:53 PM Thread Starter
tbain235
I started doing resistance test on the main battery cables. Everything is at a good 0 ohms, except one line goes up to 300-400 ohms. Im not sure if thats bad or not.
Also when I connect the battery, I still get no power to anything, and the negative terminal get really hot. The positive one stays cold. Could that be an issue with the starter? I am going to attempt to take the starter off tomorrow and bring it in, along with the battery.
tbain235 is offline
post #15 of 39 Old 12-29-2013, 07:16 PM
LumpyGrits
What is your NEG connected to??
Mine, top bolt of the starter.
LG
alternator , battery , check guages light , dead battery
