Quantcast Replace front wheel bearings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Replace front wheel bearings
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-13-2007, 04:45 PM   #1
alexrule123
Universal Cereal Bus
alexrule123's Avatar
I need to replace my front wheel bearings. i know i have the cast rotors so i need to get that hub, but i was wondering two things. First, are the 2wd hubs the same as 4wd, since only one option is given for the part and i have a 2wd and second is there any quality difference if i got them from advanced auto or napa? the reason i ask is because at advance auto they cost $124.44 and the ones at napa cost $169 each.
Thanks
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is offline   Reply With Quote
Old 04-13-2007, 09:59 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You'll need to know who manufactures them to know if it's a quailty or price difference. Can't go wrong with Timken units.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 04-13-2007, 10:02 PM   #3
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
pretty sure 2wd hubs are different
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 04-13-2007, 10:03 PM   #4
alexrule123
that is what i thought, but they do not ask if it is 4wd or 2wd
edit: the advanced auto ones are BCA and Napa does not give a brand name for theirs
Old 04-14-2007, 12:14 AM   #5
TMCXJ
I know AutoZone carries Timken. I remember paying $140 for them, last September or October. And the 2wd & 4wd are different.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline   Reply With Quote
Old 04-14-2007, 12:48 AM   #6
xj-Jen
I just bought the Timken ones from Auto Zone tonight, $145 each. Ouch! That hurt!
[COLOR=DarkGreen][FONT=Impact]1992 Cherokee Limited[/FONT][/COLOR]
[FONT=Impact][COLOR=DarkGreen]TnT Y-Link, 33"MTR's, d44, d30, 4.56, ARB's [/COLOR] [/FONT]
xj-Jen is offline   Reply With Quote
Old 04-14-2007, 06:08 AM   #7
TMCXJ
Remember to follow proper torque when reassembling. 175 ft.lbs. on the axle/hub nut, 75 ft.lbs. on the 3 bearing bolts (tighten in stages), 11 ft.lbs. on the caliper pins.
yeah I know... I sound like Towelee -- "Don't forget to torque your bolts!" instead of "Don't forget to bring a towel!"
Old 04-14-2007, 04:10 PM   #8
alexrule123
arrg i think i got the wrong hub....the wheel won't spin freely
Old 04-14-2007, 06:59 PM   #9
alexrule123
2wd and 4wd use the same bearings. I got the right hub assembly and got both installed. The only problem I am having is the place that did my brakes over a year ago cross threaded the caliper bolt and now there is not enough material for the stock bolt to work . So now i have to go to a hardware store and get a slightly bigger bolt
the tap i have that fits the threads is a M8X1.25, but there is some play. What is the next size up with the same thread count?
Old 04-14-2007, 10:06 PM   #10
alexrule123
Here are some pictures showing the 2wd hub is the same as the 4wd hub, with the execption of the spline insert.
Old 04-14-2007, 11:59 PM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You'll need to take one of the other or the one bolt to a hardware store and start trying to thread on different sized nuts till you find the one that works.
If you could find new knuckle cheap enough, that might be the other solution.
93 Sport
Specs in Profile.
Old 04-15-2007, 11:10 AM   #12
alexrule123
yeah, i am planning on doing that today
Old 04-15-2007, 12:07 PM   #13
TMCXJ
Well, you most certainly have my apology for stating that they were not the same. I have never owned a 2wd Jeep, but back when I had my old 1986 MJ (bought new), I worked with a guy that had a 1985 XJ in 2wd, and I helped him with maintenance. His front bearings had a regular cleaning/greasing schedule, and they were virtually NOTHING like my bearing/hub units. In fact, and I don't recall the exact torque now, those retaining nuts were literally just torqued very low, then loosened, then tightened again BY HAND. On the 2wd, mind you. Then cotter pins, etc., and done. Of course I don't perfectly recall the entire procedure, that was almost 20 years ago when last I did it for him. But the parts were drastically different... again, maybe my memory, I don't know. Either way, sorry for the incorrect info.
Old 04-15-2007, 12:23 PM   #14
alexrule123
Well, you most certainly have my apology for stating that they were not the same. I have never owned a 2wd Jeep, but back when I had my old 1986 MJ (bought new), I worked with a guy that had a 1985 XJ in 2wd, and I helped him with maintenance. His front bearings had a regular cleaning/greasing schedule, and they were virtually NOTHING like my bearing/hub units. In fact, and I don't recall the exact torque now, those retaining bolts were literally just torqued very low, then loosened, then tightened again BY HAND. On the 2wd, mind you. Then cotter pins, etc., and done. Of course I don't perfectly recall the entire procedure, that was almost 20 years ago when last I did it for him. But the parts were drastically different... again, maybe my memory, I don't know. Either way, sorry for the incorrect info.
it is all cool, i just wanted to let people know they are the same since i didn't know at first. Even my mechanic thought they were different
Old 04-15-2007, 02:47 PM   #15
alexrule123
i used a heli coil to fix the threads. now i have another problem, whenever i turn the wheels a lot i hear a pop and then it goes away. everything is tightened the right amount. what could this be? The pop comes from both sides, if i turn the wheel left it comes from the left side and if i turn it right it comes form the right side. i am so confused right now
Glock Forum
