replace cv or replace whole d30 front axle - JeepForum.com
post #1 of 13 Old 07-30-2013, 11:26 PM Thread Starter
maroon87xj
1987 XJ Cherokee
whats up guys. i got an 87 and the front cv joints make a bad clicking sound while in 4l. i have a parts jeep with a d30 in the front aswell. so my question is should i just do an axle swap or change the cv joints. i am not into working on cars but i got to get this going as a dd.
maroon87xj is offline
post #2 of 13 Old 07-31-2013, 12:05 AM
Holder350
1995 XJ Cherokee
Are you sure it has CV axles? Or just u joints?
Replacement CV shafts are relatively weak compared to stock u-joint assembly shafts.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 13 Old 07-31-2013, 12:29 AM
sAe23
1995 XJ Cherokee
Is the donor axle high pinion?
sAe23 is offline
post #4 of 13 Old 07-31-2013, 09:45 AM Thread Starter
maroon87xj
1987 XJ Cherokee
sorry i am a noob, whats is high pinion
post #5 of 13 Old 07-31-2013, 10:27 AM
Diamond-x
1991 XJ Cherokee
High pinion is the position of the pinion (where the drive shaft connects) relative to the centerline of the axle, below it is low pinion, above is high pinion. HP is desirable for ground clearance. The CV axle is weak compared to the D30, so swap it if you can. Where are you in BG? My in laws live between Lucia falls and the Heisson bridge.
Diamond-x is offline
post #6 of 13 Old 07-31-2013, 12:57 PM Thread Starter
maroon87xj
1987 XJ Cherokee
i live in dollars corner. west of bg going to the freeway.
i will have to go look what mine is now on the jeep. and cal my homie where the spare jeep is and have him look what it is
post #7 of 13 Old 07-31-2013, 01:31 PM Thread Starter
maroon87xj
1987 XJ Cherokee
i can feel something isnt right when i am just dd the jeep but when i put her in 4x4 and turn left or right with the front lock she makes a real bad clicking sound. i am not sure what the problem is but i have a whole other d30 front axle so i was jsut curious if i should swap them or replace parts in the axle under her now
post #8 of 13 Old 07-31-2013, 02:35 PM
sAe23
1995 XJ Cherokee
Um..what Transfer case do you have?!?
If the shift lever only has 2H-4h-N-4L, DON'T USE 4x4 on pavement!!
sAe23 is offline
post #9 of 13 Old 07-31-2013, 03:07 PM Thread Starter
maroon87xj
1987 XJ Cherokee
yea its the 231 i think. and i was not on pavement when she was doing this. i was at a fishing hole off the beaten track and got down fine in 2wd but needed 4 to get back up the slick hill. i was carless a few months ago and came across my cherokee for 400 bucks. it ran and drove fine for the old guy. nw that i have it anything and everything is going tits up. and i drive her like a grandpa so i am nt rodding on her. this jeep has to be my dd slash camping rig.
post #10 of 13 Old 08-09-2013, 04:12 PM
Diamond-x
1991 XJ Cherokee
Sounds like the timing chanin is stretched and popping over the sprocket. It can be replaced for about $100 and a few hours of labor.
post #11 of 13 Old 08-12-2013, 11:26 PM Thread Starter
maroon87xj
1987 XJ Cherokee
Where the timing chain at and what does it have to do with my 4 wheel drive? That might be a dumb question. I think I got a car trailer lined up to use to get my parts jeep home. I started looking and my rear leafs are flat.... Lol so I hope my spares are better along with the stabilizer shock and power steering hoses. Lol I need just a couple things haha
post #12 of 13 Old 08-12-2013, 11:47 PM
Holder350
1995 XJ Cherokee
I think he ment transfer case timing chain.
Sent from my phone
post #13 of 13 Old 08-12-2013, 11:56 PM Thread Starter
maroon87xj
1987 XJ Cherokee
I will have to look into that as well. This xj just keeps throwing me curve balls but I reAlly like it and would like to get her going so I can do some camping next year and some winter wheeling soon!
