Repair procedure for door protector trim - JeepForum.com
post #1 of 6 Old 11-15-2006, 05:08 PM Thread Starter
QwkTrip
The black plastic molding strip on my driver side door (parking lot ding protector?) is beginning to seperate from the door and it's only a matter of time until it falls off. What kind of glue is used to attach the molding? I assume you can just pull it off, clean the mating surfaces, and reaply glue again to fix it.
Thanks!
QwkTrip is offline
post #2 of 6 Old 11-15-2006, 05:10 PM
jeffasher1988
i just ripped mine off and picked away the back tape stuff. I like the look better.
1996 Cherokee XJ 2 Dr. Black. Auto. New Starter and NSS. Other then that its stock.
jeffasher1988 is offline
post #3 of 6 Old 11-15-2006, 05:16 PM
drewguere
drewguere's Avatar
Its 3m double sided tape...
But I recomend removing it..it looks badass
2002 GMC 2500HD 8.1L - Tow Rig
1998 Jeep Cherokee - Wheelin Rig
1988 Jeep Wrangler - In progress...
drewguere is offline
post #4 of 6 Old 11-16-2006, 05:12 PM Thread Starter
QwkTrip
Well, I suppose I have to remove it either way. I could leave it off for a few days and see if I get used to it.
Thanks!
QwkTrip is offline
post #5 of 6 Old 11-16-2006, 05:46 PM
cobra
1987 XJ Cherokee
mine was peeling off also,i put some silicone caulk on it and clamped it... havent had a problem since
cobra is offline
post #6 of 6 Old 11-16-2006, 05:57 PM
sundevilkid
sundevilkid's Avatar
Gorilla Glue all the way... if you want to put it back on. It is very very very strong (did I mention how tough this stuff is) glue (they claim it's the strongest glue on the Planet Earth)
I'm going to be putting diamond plate all along the bottoms of mine. It looks sick.
1996 XJ Classic
My sig got too long. So we'll just say it's Friggin' Sick.
sundevilkid is offline
Door Hinge Weld Broke Door Falling Off Repair DesertOne XJ Cherokee Technical Forum 9 10-23-2011 06:25 AM
door trim? streetcherokee XJ/MJ Cherokee Non-Technical Forum 7 10-26-2009 08:08 PM
Source for door protector strips? Rallred XJ Cherokee Technical Forum 1 05-15-2008 06:00 PM
98 Door trim Jimmy4321 XJ Cherokee Technical Forum 8 12-19-2006 04:18 PM
Vinyl Trim Repair tangofox007 XJ Cherokee Technical Forum 2 08-02-2005 03:36 PM
