Quantcast Renix help please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Renix help please
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 09-29-2007, 05:42 PM   #1
camjeep3
1988 MJ Comanche
Renix help please
Ok, so today i went to fix my blowby ending without any succes, i did find however that i believe i have the wrong tube from the front of the valve cover to the box, what is supposed to be there is there a valve that goes in? any pics would be great
Cam
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline   Reply With Quote
Old 09-29-2007, 05:56 PM   #2
camjeep3
1988 MJ Comanche
its an 88 by the way, and if you can tell me where to get these parts that would be great also
4.0L w/ 5spd
Old 09-29-2007, 06:17 PM   #3
Slowride63
XJ Cherokee
This should help you out.......
http://www.napaautoparts.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7 151365&Description=Emission+Hose+-+Air+Intake+Ventilation
http://www.napaautoparts.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7 151366&Description=Emission+Hose+-+Air+Intake+Ventilation
http://www.napaautoparts.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7 151367&Description=Emission+Hose+-+Air+Intake+Ventilation
88 Cherokee. 4.5". 33's
90 Cherokee. 2" BB . 31's
97 Grand Cherokee. Stock for now
Red Jeep Club #364
Low Output 4 Cylinder Jeep Club #101
Slowride63 is offline   Reply With Quote
Old 09-29-2007, 06:35 PM   #4
camjeep3
1988 MJ Comanche
Thanks, that helps alot
4.0L w/ 5spd
Old 09-29-2007, 07:16 PM   #5
tangofox007
Rockauto.com prices are about 20% less than NAPA. Look under "Emissions" for "PCV Valve Tubing" and "Vacuum Harness."
tangofox007 is offline   Reply With Quote
Old 09-29-2007, 07:18 PM   #6
camjeep3
1988 MJ Comanche
yeah i just looked there, thanks, hopefully this thing will stop leaking oil now
4.0L w/ 5spd
Glock Forum
