Renix-Crank Postion Sensor Location
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#1 | |
Where exactly is the CPS located on a '90 renix?
Thanks Adam
#2 |
forum supporter
It is on the transmission bellhousing. If you are looking at the front of the engine it will be around the 1 o'clock position. Or on the drivers side just a bit lower than the top.
#3 |
here's a link to a pic- Jeep Cherokee Engines - RENIX (non-HO) Engine Sensor Diagnostics
-should be towards the bottom. someone just showed me this earlier. Last edited by scottyknows50; 11-21-2009 at 06:01 PM.. |
#4 |
that is a good pic of it. its at the top of the belhouseing. i changed mine from the engine bay reached down behind the intake mani
'90 Cherokee 4.0l, dodge hd NP231 w/SYE, open cooling system conversion, HP44 w/ trutrac, 9" w/ detroit, 6in lift, 4.56s, 36's, custom steering & adj track bar, removable doors, TCU control box, on board air, much more |
#5 | |
Only if the vehicle has rolled over. |
#6 |
the picture was towards the bottom of the page.......... Last edited by scottyknows50; 11-21-2009 at 05:19 PM.. Reason: took out quotes |
#7 |
actually tango, you took both sets of quotes out of their respective contexts. if the bellhousing was a clock, the cps would be at 1:00- from the front of the vehicle. if looking from the rear it'd be at 11:00. next time think a bit before trying to "call us out" on our posts.
#8 |
wow, that was rough. Scotty, maybe the OP would better understand if you explained it from the point of replacement....we know your arms are not long enough to reach over the engine and down to the CPS!
Get on your back and shimmy under the truck. Look on the left side of the transmission (Drivers side) up on the top of the bell housing and you will see it. The wires going to it are pigtailed into the harness with the sensors for the transfer case. I used a long 1/4 swiveling extention to get to it a bit easier, and make sure you put that rubber cover back in when you replace it. New CPS units do not come with this gasket. You can do it through the engine bay, but I found that I could not see the bolts holding it in from that position. |
#9 | |
#10 |
man, them was some big words....I had to read that twice Tango, but I agree with you. The OP will be flipping his jeep and running in circles now!
#11 | |
#12 |
if you were to read it in its context you would understand it.
#13 |
k, I think we got him what he wanted.
#14 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
