Renix cooling system question - JeepForum.com
post #1 of 11 Old 07-17-2013, 04:46 PM Thread Starter
Holder350
1995 XJ Cherokee
So, I bought a 90' for $300 and have been repairing and making it a driver for the past few days.
It has the classic renix closed cooling system which the PO had replaced the pressure bottle on recently.
Everything on the system works with a new thermostat (195*), but my temps never get up to the normal 210 range. Every other Jeep I've owned always runs in the 210 range.
Just asking, to see if it's normal or not.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #2 of 11 Old 07-17-2013, 05:16 PM
mybuick
on the back of the head on the driverside there will be a coolant sensor. i usually take that out and fill the coolant til coolant comes out from the sensor hole. this is how i make sure there is no air in the system.
mybuick is offline
post #3 of 11 Old 07-17-2013, 05:44 PM Thread Starter
Holder350
1995 XJ Cherokee
I'm fairly sure there is no air in the system, I flushed the system today with the upper hose off and the water hose in the radiator. Thermostat opened up and I got the entire system clean.
I covered the radiator with cardboard and got it hot enough for the electric fan to come on.
Oh well, might have a weak sending unit or gauge.
post #4 of 11 Old 07-17-2013, 06:38 PM
djb383
Did u actually install a 195 stat or is the PO saying he did? Doesn't take much to remove/test the stat.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #5 of 11 Old 07-17-2013, 07:02 PM
Motorcharge
Where is it getting to? Double check your temps with an IR gun, the old gauges aren't 100% accurate.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #6 of 11 Old 07-17-2013, 08:33 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The standard black chinese coolant bottle caps are junk. Imagine that. Go to Napa and get a 703-1396 cap for your bottle. see what happens.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 11 Old 07-17-2013, 08:35 PM Thread Starter
Holder350
1995 XJ Cherokee
Temps are getting up past the hash between 100 and 210 so I'm guessing the gauge is showing about 180.
I replaced the thermostat with a new 195, the one I removed was also stamped 195.
I'll have access to a IR thermometer tonight and check actual temps
post #8 of 11 Old 07-17-2013, 08:38 PM Thread Starter
Holder350
1995 XJ Cherokee
I'll get a cap tomorrow cruiser, (or atleast one ordered)
Can't thank you enough for all the help you've given already on this Jeep, even if you don't realize it, you are the renix king! Haha
post #9 of 11 Old 07-17-2013, 08:40 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
In a day or 2, JF will have a complete list of my Renix tips available for everyone. Enjoy your Renix Jeep!!!
post #10 of 11 Old 07-17-2013, 10:04 PM
5-90
5-90's Avatar
1988 XJ Cherokee
And that's a bad thing?
I've owned FIVE RENIX XJs to date, one converted by PO. The converted one ran hottest of the five.
I had managed to "pull down" the op temp on three of the other four (the fourth is a parts donor) through various small mods, and they all ran 190-195*F with no ill effect on running, fuel economy, fuel efficiency, or tailpipe emissions.
The nice thing? RENIX doesn't care about Op Temp like OBD-I/II does, so leave it and go! I seriously doubt you need to "burp" the system as it stands - a gas pocket would collect behind the thermostat if present, which prevents it from opening, and would cause a drastic overheat condition.
You're good - don't worry about it unless it "spikes" on you.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #11 of 11 Old 07-17-2013, 11:04 PM Thread Starter
Holder350
1995 XJ Cherokee
Well....no, lol I just knew a low operating temp could cause issues on later Jeeps. This is the first renix I've owned so I just thought it would be the same.
I do know I'll more than likely be swapping the abs system to a later model non abs when it dies.
A question you might be able to answer is: I have a 92 parts doner that has factory abs on it, could I use the master cylinder, booster and prop valve from it when I do my swap?
