Removing Transmission Cooler Lines from Radiator - JeepForum.com
post #1 of 11 Old 10-28-2006, 10:42 AM Thread Starter
bigbrowndog
I am pulling the entire drivetrain from a wrecked 98 XJ and putting it in my 88 YJ. I disconnected the upper transmission cooler line on the radiator with no problem, but the lower line does not simply come off and I know there must be a way.
You can undo the nut that attaches the line to the radiator, but the fitting does not come out of the radiator. I know you shouldn't have to remove the entire line to change out the radiator, but I just don't know the trick to getting this fitting off. And my Chilton manual is silent on this one.
Any help is appreciated. I hate to destroy the lines as I may need them with my new radiator for the YJ. Any help is very much appreciated.
Thanks
Ty
bigbrowndog is offline
post #2 of 11 Old 10-28-2006, 11:09 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
FSM says- quick connect fitting release tool 6935 may be needed.
Must be one of those snap together type fittings.
CJ7-Tim is offline
post #3 of 11 Old 10-28-2006, 11:24 AM
Rock Kustoms
Rock Kustoms's Avatar
cut it, its prolly corroded solid, just cut it , and replace w/ some 3/8" brake line, flare the ends, and slip the rubber line from you jeep over it and hose clamp
Rock Kustoms is offline
post #4 of 11 Old 10-28-2006, 11:34 AM Thread Starter
bigbrowndog
Thanks you both for the quick response. Looks like I am going to have to cut it as I don't want to buy a tool I may use only once or twice.
Thanks for the help.
Ty
post #5 of 11 Old 10-28-2006, 11:36 AM
Kuasimodem
Kuasimodem's Avatar
Push the fitting together, sqeeze the two tabs in with a pliers and pull the fitting apart.
Don't lose the two O rings!
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #6 of 11 Old 10-28-2006, 12:17 PM
Rock Kustoms
yeah, if itll come apart, thats how to do it....if
post #7 of 11 Old 10-29-2006, 02:30 AM
Habibi
yo no prob cheap *** tool from advanced autpo parts for like 3 dollers... i got the high tech cool one for 11 dollers and its for all fuel lines and tranny lines i wound intest.. u might need it one day
98 XJ 4.5 re lift, 33x12.5x15, surco roof rack, eclipse head unit, all aftermarket speakers, 4 off road fog lights, a set of awesome air horns, half home made front bumer.
needs alot of work...
things to do: get a sye and driveshaft, cb and pa?, headlights?, any other ideas?
Habibi is offline
post #8 of 11 Old 10-29-2006, 07:21 AM
LJ Dave
I have cut the tranny cooling lines on several older vehicles when replacing the radiator or adding a tranny cooler and have always replaced it with a small piece of hose, the kind you get with an aftermarket tranny cooler. Those lines do not have that much pressure in them and a hose with hose clamps will hold up just fine for the life of the vehicle.
Dave S.
LJ Dave is offline
post #9 of 11 Old 10-29-2006, 10:45 AM Thread Starter
bigbrowndog
Thanks Everyone. I just went ahead and cut it. Then I found I needed the same tool for the fuel rail. After looking at the tools on the internet and not wanting to make the trek to the auto parts store, I made my own tool.
I took a 1/4 inch wide piece of sheet metal (it was actually from one of those thin pieces of sheet metal you use to disengage your aftermarket stereo from the box). I wrapped it tight around the line and pinched it so that it looked like a band on a bird's leg. Then I slid it in and was able to disengage the quick connect on the fuel rail. Gonna just leave the band on their in case I need to disengage it again after I get this setup in the 88 Wrangler.
thanks again..
Ty
post #10 of 11 Old 01-09-2010, 05:34 PM
ckisela
1994 XJ Cherokee
Can anyone tell me the order the O-Rings go back on for that fitting?
ckisela is offline
post #11 of 11 Old 08-24-2010, 01:36 PM
Decscorpion
NOICE!!!!!!!! theres two o rings!!!! theres an order????
1. 1996 Jeep Grand Cherokee Laredo V8 5.2 l
2. 1993 Chevrolet K2500 V8 5.7 l
3. 1998 Jeep Wrangler 2.5 l
Thats all i got..
Decscorpion is offline
transmission cooler lines. blu3fan XJ Cherokee Technical Forum 9 01-10-2010 11:58 PM
Removing stock trans cooler lines? PhilipJ XJ Cherokee Technical Forum 8 09-10-2009 08:45 PM
trans cooler lines to radiator? sasquachYJ XJ Cherokee Technical Forum 3 03-14-2009 12:07 PM
Transmission Cooler Lines KyleS XJ Cherokee Technical Forum 5 02-21-2006 09:45 AM
transmission cooler lines BackDraft XJ Cherokee Technical Forum 9 03-12-2005 06:12 PM
