Quantcast Removing 97+ doors with power *write-up* - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Removing 97+ doors with power *write-up*
Old 03-29-2009, 07:58 PM   #91
XJ98beast
1994 ZJ
now im not as lifted as all of you but idc i love this mod!!!
Then the homebrew locking center console to top it off!!!
1st Jeep (HULK): 98' XJ 4dr, 31x10.5, Flareless, 2'' BB,Bull BAR!!, Side Rockers, Roof Rack, 8 Lights, Bedlined, CB
2nd Jeep (BLACK PEARL): 95' XJ 4dr, 33x14.5 Boggers, 6.5'' Rough Country
1st Car: POS 1g Talon (biggest mistake)
3rd Jeep (CLIFFORD): 94 ZJ, 5.2L, 4.5" Rustys, 33x12.50, Red. FUTURE MODS: Sun visor, stinger, some good lookin flares, 4:88 Gears
XJ98beast is offline   Reply With Quote
Old 03-30-2009, 04:45 AM   #92
Jeep Cherokee
These pins work well also..
https://www.dormanproducts.com/cgi-bin/vm91corp30r/item-dtl.w?sid=nBelajSCkIbykIPo009667626892543051&item= 38439&icrid=0x00679be8&clt=hwrap1&vsrch_str=&vsrch _brand=&vsrch_cat=&st_amount=&end_amount=&start=&v from=&prev=&vnext=&category_list=:0
Red Jeep Club Member #16
Become a fan of the Jeep Cherokee XJ Facebook Page
Jeep Cherokee is offline   Reply With Quote
Old 04-07-2009, 04:45 PM   #93
bmyohn
Youngin'
bmyohn's Avatar
where is the electrical connections for the rear doors? are the in the b-pillar or are they underneath the trim at the bottom of the door?
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 04-07-2009, 08:20 PM   #94
Amadeus3
1997 XJ Cherokee
Originally Posted by dcorn View Post
I'm just telling you what I've heard many times on this forum and others. I've seen an XJ wheeling without a hatch as well, but I definitely wouldn't do it. Seems to me the hatch could definitely play a part in lateral rigidity.
Plus, mine is metal and I'm sure it weighs more than the doors, so I wouldn't even want to try to get that off by myself.
I would need some pretty incontrovertible evidence to believe that the hatch adds any structural integrity to the vehicle. It latches at one point at the bottom in the center of the door on a latch that allows at least an inch or more of lateral movement and is held away from the body of the jeep by rubber bumpstops which allow an inch or more of longitudinal movement. It just doesn't seem like it can strengthen the structure at all. Especially since any forces would be transferred directly to the dinky little latch holding the hatch shut and I don't think it was designed to handle any job besides keeping the hatch shut.
6.5" Rough Country lift, locked on 35x12.5x15" BFG KM's, Nate's 4x4 Slimline, Smittybilt XRC10, skids, random junkyard upgrades
Amadeus3 is offline   Reply With Quote
Old 04-20-2009, 12:54 PM   #95
xjtroudt
Great write up. Cant wait to do this to mine
xjtroudt is offline   Reply With Quote
Old 04-24-2009, 11:49 AM   #96
sharpie
German car snob
sharpie's Avatar
1999
Wow, I am glad this thread blew up with discussion. Right on, guys!
- Brian
Klein Concept and Design
KCD Website
Follow us on Facebook!
XJ Writeups:
| DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE
sharpie is offline   Reply With Quote
Old 05-18-2009, 12:42 PM   #97
Bane7962
I go thru mud too quickly
Bane7962's Avatar
Can you just take pre 97 hinges out of a junkyard or something and put them on a post 97?
And what about doing all 4 doors?
Same thing, or a bit different?
Bane7962 is offline   Reply With Quote
Old 05-18-2009, 01:10 PM   #98
Jon00XJ
Originally Posted by BeachinXJ View Post
Any hardware store.
I would suggest using bolts. I have a set that I can slide through the hinge with no sagging on either door. If you grind the threads off it makes it super easy to take on and off. I also can remove/put on each door without any help.
What size bolts do you use? Im really wanting to do this but not if my doors are gonna sag
Jon00XJ is offline   Reply With Quote
Old 05-18-2009, 02:10 PM   #99
tuckinauster
Originally Posted by Redrum8675 View Post
why cant you just remove the 6 torx bolts on each door....would that disconnect the door from the hinge without having to cut the pin?
You could, but getting the doors to line up perfectly again is a huge pain.
Sniper Central
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline   Reply With Quote
Old 05-18-2009, 02:14 PM   #100
Jon00XJ
Yeah I wouldnt recomend that you would have to realign the hinges and my buddy can tell you its not fun at all and you never get it right again
Old 05-21-2009, 07:44 PM   #101
xjjeepin109
nice lookin jepp
xjjeepin109 is offline   Reply With Quote
Old 01-21-2010, 10:45 PM   #102
jeepster425
so, you unplug the wires for the doors, what do you do then?
Do your pull it out of the side part and up through the hole?
D30 front/ D44 rear
__=====,o00o,
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|
lllllll|
{o}_} {o}_}--o-}_}
jeepster425 is offline   Reply With Quote
Old 01-21-2010, 10:51 PM   #103
EricsXJ
The Post man
EricsXJ's Avatar
Pull them through the holes in the A-pillar before you lift the doors off.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 01-31-2010, 12:20 AM   #104
Bain98xj
ok well another think about just removing the hinges. couldnt you just outline the hinge and then just line it up that way. either way as soon as i get back to texas i will be taking my doors off..
Bain98xj is offline   Reply With Quote
Old 02-07-2010, 09:38 AM   #105
brianglawson
^^^^ i still think it would be dfficult to line them up, however it does sound like a nice alternative if you had a good specific wrench to get in the there easy everytime, but it would definately be a two man job
brianglawson is offline   Reply With Quote
Glock Forum
