Quantcast Removing 97+ doors with power *write-up* - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Removing 97+ doors with power *write-up*
Old 03-12-2009, 06:07 AM   #76
dcorn
Originally Posted by Amadeus3 View Post
Are you joking? I seriously doubt that its structural. It only attaches on the bottom by the latch and it is held in place by rubber bumpstops which have quite a bit of give to them. I've seen XJ's wheeling with no tailgate doing some pretty hardcore stuff with no issues.
I'm just telling you what I've heard many times on this forum and others. I've seen an XJ wheeling without a hatch as well, but I definitely wouldn't do it. Seems to me the hatch could definitely play a part in lateral rigidity.
Plus, mine is metal and I'm sure it weighs more than the doors, so I wouldn't even want to try to get that off by myself.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 03-12-2009, 07:27 AM   #77
bmyohn
Youngin'
bmyohn's Avatar
it is possible...the only times ive ever seen someone wheelin without a trunk, they had a strong interior cage to back it up
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 03-19-2009, 08:14 PM   #78
dkfireblade
I first want to thank everyone for previous write-ups. I have looked through everything, maybe I missed this part.
I am stuck at the wires part. How do I feed the wires and plugs through the body? Any help would be appreciated.
dkfireblade is offline   Reply With Quote
Old 03-19-2009, 10:57 PM   #79
BIGplansNOmoney
You must remove the body side inner and outer gaskets... take some dykes to them thats easiest... there is a large hole in the inner doorframe where they used to be...then just unplug the driverside 3 plugs and passengerside 4 plugs and feed them through...
XJ - My anti-drug
JEEPERS: (GE-PURRS): Proud, Arrogant, Egotistical Creatures of the human variety that have an undying passion for motor vehicles manufactured by the JEEP company.
BIGplansNOmoney is offline   Reply With Quote
Old 03-19-2009, 11:00 PM   #80
BIGplansNOmoney
As far as hatch less... I thought about it and I dont think wheelin around would do much...but i dunno... any and every hatchless XJ i've seen have had some cage support, IE... JEEPSPEED XJ'S for example that have the spare tires hanging out the back
XJ - My anti-drug
Old 03-20-2009, 01:23 PM   #81
dkfireblade
woo! finally got the front doors off. thanks again for everyone that has done this before me, it made it a lot easier. I dont think i would have done it without these write-ups.
Old 03-20-2009, 02:06 PM   #82
BIGplansNOmoney
Me neither lol thanks to my trusty jeep forum...
XJ - My anti-drug
Old 03-21-2009, 07:20 PM   #83
dkfireblade
alright,
door off..check
hinges remounted...check
able to get doors back on... not so much
I've got everything on, holes lined up, but i cant seem to get a new hinge bolt through the top of each hinge. I have tried with it mocked up on the vehicle and it will not go in.
I took the door, set it on the ground and i can not get the bolt in their either.
When i go to put the bolt in it has to go in at a slight angle due to the door's design. However, the angle is too great to be able to go through the door-side hole and the inner vehicle side hole. It fits fine coming from the bottom up. only problem there is gravity.
what has everyone else done to remedy this situation, i.e. what bolts are you using, did you bend the door to make it fit, etc..
I am using a wire lock pin from home depot, 5/16" x 2-3/4"
I tried getting a pin with a cotter pin lock, but i couldnt find any that were long enough to go through both sides of the hinge.
thanks again y'all for any help.
Old 03-21-2009, 07:33 PM   #84
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
grind the pin down until it fits. I just took bolts that were close and ground the threads off.
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Old 03-21-2009, 07:50 PM   #85
dkfireblade
its not really a diameter issue, they fit perfect when the hinge is off the door.
its more of a length to required angle issue.
the pin it self only extends past the hinge by 1/8" 1/4" not much room to cut off.
if i go with a shorter bolt, i am worries that only one connection point per hinge may cause unneeded stress on that junction leading to hinge flex.
Old 03-24-2009, 09:57 PM   #86
dkfireblade
i went to www.mcmaster.com to get the perfect bolt. one of my buddies is a research engineer at georgia tech and pointed me that way. awesome site if anyone needs parts for pretty much anything.
i got 8 5/16", 3" long ball lock pins for less that $16.
Old 03-24-2009, 10:46 PM   #87
Kpat
Any pictures of all 4-doors off?
Also. I was under the impression that the door's are part of the structural integrity of the Jeep. Am I wrong??
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan!
Kpat is offline   Reply With Quote
Old 03-28-2009, 11:56 PM   #88
FleXJ00
Thanks for the write up, sharpie
No regrets...
^^...and no the doors are not structural...you can wheel with all four off if you like...
BLACK JEEP SOCIETY #256
2000 Cherokee Sport 162K
...with some stuff
I SUPPORT ROUGH COUNTRY
AND TREADWRIGHT
FleXJ00 is offline   Reply With Quote
Old 03-29-2009, 01:15 AM   #89
XJcruiser
Door do play an important roll structurally in the event of a collision, however. But you can definitely wheel like that!
XJcruiser is offline   Reply With Quote
Old 03-29-2009, 04:50 PM   #90
FleXJ00
yeah i think if i get t-boned with my doors off, im dead... haha
...with some stuff
AND TREADWRIGHT
Glock Forum
