Removing 97+ doors with power *write-up*
#61 | |
x2...10 chars
[SIZE="1"][CENTER]'98 XJ Sport, 4.0L, AW4, NP231, HP30/8.25" 3.5" RE Superflex, Full Leafs, OME's All Around, JKS Trackbar 31x10.5R15 Mickey Thompson Baja MTZ's on 15x8 Rockcrawler's (3.75" BS) C4x4 Front Tow Hooks/Rear Hidden Hitch[/CENTER][/SIZE] |
#62 |
Have fun lining the door back up so it'll close properly every single time you put it back on. Those bolts are the adjustment points of the hinges so you want to leave them exactly where they were from the factory. Its much easier to just cut the pins and get something else to use as pins. I used 5/16" bolts held on by nuts. Very simple fix.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored 2012 Subaru WRX Limited |
#63 |
but arent there three holes inside the door that match up exactly with the three holes on the hinge, so wouldnt you just have to get someone to hold the door in place, line up the holes, and screw everything back in place?.....i dunno seems easier to me
#64 |
The three holes inside the door move around so you can adjust the door gaps.
#65 |
![]() Jimmy is right. The holes on the frame are intentionally larger then the holes on the plates, to allow for adjustment. Whats supposed to happen, is the plate can be loosened, and adjusted up, down, front or back, to allow the door to line up properly, plus you can put shims under it to get it to adjust further out. So no, Thats not easier. quick release pins, or bolts, is easier. You want to leave the jeep-side half of the hinge on the jeep, and the door-side half on the door.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups. PS: Installing HID's in stock housings is bad. Here is why. "When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009 |
#66 |
oooo alrite....thanks for the info
#67 |
Moparrrrrrrr
yea i used 5/16 bolts and they work perfectly fine.
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness! -1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE -1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted |
#68 | |
![]() ALSO!!!! Be extra careful with the wiring harnesses coming outta the doors if you have power windows/ mirras/ and locks because they're really easy to bend or pinch... (I Have no power windows) lol and I rolled them down to take em off... lol and its raining!!!
XJ - My anti-drug JEEPERS: (GE-PURRS): Proud, Arrogant, Egotistical Creatures of the human variety that have an undying passion for motor vehicles manufactured by the JEEP company. |
#69 |
I took my doors off this weekend, and I'm looking for an alternative to removing the dome-light buttons. I'm pretty sure these run off the IOD fuse, so I can't remove that, but are there any other options to shutting of the lights beside removing the buttons, or the bulbs? I'd like to run a switch, but I'm afraid I would have to tap into all 4 buttons.
#70 |
Everthought of removing the rear lift gate? I was looking and I thing the Pin replacement would work just the same...
#71 |
only in an XJ baby... the removable tailgate... EAT IT WRANGLERS!!!
ALSO if you do the mod and your doors ain't lined up right you can adj. them... fairly easily... with all this talk of the doors being on track and ****... theres an adj. plate on the backside of the door... that's what the 3 doorside hinge bolts go into... it moves around... IT WAS MADE FOR THIS PURPOSE... get a friend to give you a hand and loosen them... do the adj. and tighten them back up... might take a couple tries but its faster than waiting for a reply to your post saying "WILL I EVER GET THE FACTORY SEAL" ![]()
#72 | |
Don't do it, its structural.
#73 |
Are you joking? I seriously doubt that its structural. It only attaches on the bottom by the latch and it is held in place by rubber bumpstops which have quite a bit of give to them. I've seen XJ's wheeling with no tailgate doing some pretty hardcore stuff with no issues.
#74 |
Yes thanks for the info !
#75 |
Also...
Does anyone know of any basic hardware that can be used as a hinge pin bushing??? they're WAY to pricey for what its worth and almost anyone that does this mod soon realizes their bushing are shot... ...I looked for something similar at hardware stores and such and O'Riley's ain't the right size... not a big deal just throwin it out there...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
