Removing 97+ doors with power *write-up*
#16 | |
German car snob
more pics coming tomorrow.
- Brian Klein Concept and Design KCD Website Follow us on Facebook! XJ Writeups: | DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE |
#17 |
Where these new pics at?
#18 |
x2 i would like to see some more pics
#19 |
Youngin'
sharpie..did u ever go all four off??
is the rear the same as the front??
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#20 | |
German car snob
I havent done the all four yet, I dont usually use the rear seat at all, so I keep em. I assume they are the same, but I think it's tougher to get the plugs out, because they are right near the seatbelt roller for the front seat, I believe.
#21 |
What do people do about the wiring in the doors? Anyone have ideas for quick disconnects?
Aaron 1999 XJ @ 6” on TSL 35s w/ Aussie D44 & XRC8 |
#22 | |
If you remove your kick panels their is a plug behind them and all you need to do is undo it and feed it out. |
#23 |
i know there have already been questions asked about doors sagging, but would this cause water to leak in through the seals? bc i want to go doorless but dont want a soggy/rusty floor
'01 XJ Sport. 4.0 I6 Auto tranny, command trac xfer case 60K miles Preaty much stock...... =( [I]"The Jeep 4.0L I6 has been rumored to make a growl so incredible, it will scare supernatural beings"[/I] -Uncyclopedia |
#24 |
where can i get those pins?
1991 jeep yj 2.5 EXPERIENCE ISNT BOLT ON I DONT GO FAST, I GO ANYWHERE |
#25 |
hmm i musta been lucky with my 97, i have the older style hinges
oh well now i can get my buddy to make his '00 doorless lol good write up |
#26 | |
anyone please ![]()
#27 |
I have a 00 and have removed the front doors (kids so I wont remove the rears) and I do have a little sag on the drivers side. I am thinking about just welding a small piece inside the hinge to help support the weight of the door.
Thanks for the wright up... ![]()
2000 XJ Classic 4.0 rustys 4.5in Locked Flowmaster Exhaust, K&N Filter System 33's and cut, Front tow hooks. (more mods to come$?) "Maybe, just once, someone will call me 'sir', without adding, 'you're making a scene'" |
#28 | |
Resident McGeek
I would suggest using bolts. I have a set that I can slide through the hinge with no sagging on either door. If you grind the threads off it makes it super easy to take on and off. I also can remove/put on each door without any help.
Kyle - I tag stuff® 2000 Jeep XJ - Chopped / Locked Join the XJ Owners Club | Download the iMarn® iPhone App!1997 Jeep XJ - Daily Driver 2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather! Homepage | Jeepspace Group|Twitter!|Facebook |
#29 |
awesome im going with bolts then
#30 |
im gunna do this soon so i was wondering what everyone thought was the best solution as a pin. I think i heard someone suggest drilling out the holes to 3/8" and using a 3/8" bolt or pin. Has anyone tried this? Why would a bolt be better? sorry to bring up an old thread
Red 1999 Cherokee sport: RE SF 3.5" kit w/ 1" shackle and spacer, RE HD trackbar and bracket, Cragar soft 8's w/ 32" maxxis Bighorns, Aj super rock rails, JCR offroad Stage 2 bumper w/ loop, flowmaster super 40, Hidden hitch. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
