Remove/Replace AC Clutch Bearing - JeepForum.com
post #1 of 2 Old 05-31-2012, 02:59 PM Thread Starter
leichte
I have an 87 XJ making an awful racket. I have ruled out the water pump, clutch fan, idler pulley, power steering pump/pulley, and the distributor. When I took of the belt the noise was gone. I'm thinking it's the clutch bearing on the AC compressor.
Can anyone tell me how to get the clutch off the compressor so I can inspect and possible replace the clutch bearing?
Thanks!
leichte is offline
post #2 of 2 Old 05-31-2012, 06:26 PM
AZ Jeff
2014 JK Wrangler
This will tell you everything you need to know:
http://www.sanden.com/originals/imag...uide_Rev.2.pdf
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
a/c , air conditioning , bearing , clutch , noise
can i replace the rods and bearing from the bottom ? migsk8 XJ Cherokee Technical Forum 21 08-31-2010 02:19 AM
Access to remove/replace radio Rallred XJ Cherokee Technical Forum 4 05-13-2008 05:18 PM
So can I remove and replace the Header Panel myself? Lution XJ Cherokee Technical Forum 6 01-11-2007 03:57 PM
Rear whell bearing replace on D35 Catalina XJ Cherokee Technical Forum 3 11-05-2006 08:28 PM
Wheel bearing going out, how tough to replace? LXguy XJ Cherokee Technical Forum 6 08-21-2006 12:29 AM
