Refinishing my bumpers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Refinishing my bumpers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 04-16-2014, 07:28 PM   #1
firecat1981
Figured I post this up here in case anyone has this issue.
The previous owner really messed up the plastic on my truck, he took a scothbright pad to them trying to get rid of oxidation and the old luv bug damage. No plastic "restoration" products worked, not did heating. So I was faced with either replacing them, or recoating. I redid the grill and headlight bezels after fixing the cracks the same way, so I knew it would work out ok.
Prep: I scrubbed the bumper with soapy water, sanded lightly with 220, the wiped clean with denatured alcohol.
Before: it was a lot worse then the picture shows.
Finished: I used several light coats of Duplicolor Bed Armor, it goes on spotty, but dries to a uniform fine grain finish. Then 2 coats of Krylon fusion satin black. I am pleased with the results.
Here you can see the unfinished fender flare, the whole front was just as bad before.
What do you guys think? I'm pretty happy with it, and the krylon touches up easily is need be.
firecat1981 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2014, 08:57 AM   #2
scupking
Looks good!!
scupking is offline   Reply With Quote Quick reply to this message
Unread 04-17-2014, 08:06 PM   #3
firecat1981
Thanks, I can't wait to get it all finished.
Unread 04-18-2014, 10:29 AM   #4
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Looks good!
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
NJ F-Body Owners Association
Tru2Chevy is offline   Reply With Quote Quick reply to this message
