recovery gear help - JeepForum.com
post #1 of 4 Old 11-11-2008, 06:58 PM Thread Starter
bingolli
1993 XJ Cherokee
recovery gear help
so i just realized that i need some recovery gear! i'm looking into some tow hooks for up front and a hitch for the back but i'm not exactly sure what to look for in terms of load rating, towing capacity, etc... if someone could explain what i need to look for it would be great. i also want to get a snatch strap, would a 20,000 lb one be enough? any and all help is appreciated!
'93 sport - 32x11.5 Maxxis Buckshot Mudders - 4 inch homebrew lift - Rancho shocks - Safari Snorkel knockoff - KC slimlites - silverstars - Midland CB - K40 CB antenna - rooftop tent
bingolli is offline
post #2 of 4 Old 11-11-2008, 07:40 PM
funinmud
If you get a 2" receiver in the rear, and tow hooks using the proper brackets up front, you should be good to go. 20,000 lbs should be a good strap but I like to go as best I can with my funds, so I'd get the 30,000 or more one. But that's just me. Make sure you get a strap without hooks on it, and use d-rings, or the like for connections.
-James
98 XJ on 32's and 2-3" lift, locked, armored, and ready to rock.
funinmud is offline
post #3 of 4 Old 11-11-2008, 08:54 PM
nrpalmer32
1987 XJ Cherokee
For the tow hooks upfront I would believe that most people on here are going to recommend C4x4 Tow Hooks and for a rear 2" receiver I'd go with a class III. I have a 1 1/4" receiver on mine but thats what it came with I plan on building a custom bumper soon. I also have the C4x4 tow hooks waiting to be installed.
nrpalmer32 is offline
post #4 of 4 Old 11-16-2008, 08:22 PM Thread Starter
bingolli
1993 XJ Cherokee
could i use these tow hook mounting brackets to mount a hook on the rear?
http://www.quadratec.com/products/76045_802.htm
its just cuz hitches are pretty expensive here and i wouldnt really be doing any towing, i just need a recovery point in case i get stuck
bingolli is offline
cheap recovery gear wyojeep92 XJ Cherokee Technical Forum 6 01-28-2009 03:33 AM
Best Recovery Gear, Lockers and Armor jeepinsane89 XJ Cherokee Technical Forum 2 08-06-2007 04:21 PM
Recovery Gear MK3XXX XJ Cherokee Technical Forum 8 12-05-2006 06:18 PM
recovery gear and what not mattyjeep XJ Cherokee Technical Forum 2 09-29-2006 06:37 PM
Attempted Recovery=I need recovery points XJ-NoDough XJ Cherokee Technical Forum 13 05-09-2005 10:32 PM
