Rebuild Vs. New Engine - Page 7 - JeepForum.com
post #91 of 107 Old 06-12-2013, 07:03 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Since the new owners won't allow you to post pics from the app, I don't be able to show y'all what's going on. Got the engine out, using the 88 block, my 93 head, and a master kit.
I'm letting the machine shop rebuild my engine because they're doing it cheaper than I could do it myself. Should be ready this week or next.
I'm going to get new injectors as well. How do you determine if the distributor is still good?
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #92 of 107 Old 06-16-2013, 11:18 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Bump
post #93 of 107 Old 06-16-2013, 02:50 PM
CCKen
CCKen's Avatar
[QUOTE=Flyordie;12677455](now 2.7L and puts out as much torque as a Renix 4.0)..
Okay.
CCKen is offline
post #94 of 107 Old 06-21-2013, 06:54 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Picking up the rebuilt engine today! Also, bump!
post #95 of 107 Old 06-24-2013, 09:30 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Does anyone follow this anymore or do I need to make a new thread? :/
post #96 of 107 Old 06-24-2013, 05:01 PM
car5car
2002 M-38
I was repairing engines for 20 years. Here is my opinion.
First,bad engine has to be diagnosed, because decision has to be based on which part is bad. If you have bad head, there is no reason to buy another engine.
If problem is in block, you have to know which part is bad. Piston and connecting rod can be replaced. Pretty much any crankshaft can be repaired for about $100 +you'll need new bearings $60-90.
If your mechanic says "engine is blown", you need to find another mechanic
01 XJ 2wd 4.0
car5car is offline
post #97 of 107 Old 06-25-2013, 06:51 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Piston #5 had a hole in the very side, scored the wall. I'm thinking it was the injector going bad that contributed. A lot of the cooling ports were clogged as well in the head to the block.
It also had a main bearing knock ever since I bought it. The machinist gave me a really fair price, cheaper than I could of done it myself. It's been completely rebuilt.
post #98 of 107 Old 07-13-2013, 08:02 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I am double checking everything, and it should crank over today!! If you have any tips or advice, let me know now!
post #99 of 107 Old 07-15-2013, 11:27 AM
jeepkid03
Winning
jeepkid03's Avatar
About how much did it cost for the rebuild if you don't mind me asking?
Make sure and post pics of the finished product!
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #100 of 107 Old 07-15-2013, 11:57 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I'll upload pics when I get to a computer! 1100 for the rebuild plus a lot more, I'll itemize it once I get off work.
Rebuilt distributor-60
Ford rebuilt injectors-64
Oil pressure sender-30
Gasket kit-70
T stat, coolant- 30
Brake cleaner, degreasers, etc-30
Paint-40
New lower and upper hoses- 25
Rtv, loctite, dielectric grease etc -25
Coolant temp sensor-15
Misc. hoses- 20
12 quarts of oil and two filters-45
Oil Pump-60
More to come....
post #101 of 107 Old 07-15-2013, 12:15 PM
XtrailratedJ
Where in Tampa are you located?
96 XJ 4.0L/AX15/NP231/AUSSIE'D D30/C8.25/4.5" RE LIFT/33'S/BUMPERS, SLIDERS, ETC...
"I pitty the fool who lists D30's and 31's, then tries to talk **** on PBB":
Originally Posted by Durt_Diver:
Those pics might be a little too flexy for this thread. You don't happen to have any pics of your friends xj on a curb by chance?
XtrailratedJ is offline
post #102 of 107 Old 07-15-2013, 06:26 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I was in the USF area, but had to move to Riverview temporarily. Moving back to the area soon...
post #103 of 107 Old 07-17-2013, 06:29 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Just an update! Oil pressure is awesome, idles perfectly, gas mileage is beautiful. Odd quirk of reading hot after coming to a stop, e fan turns on right on the white mark before red. Brings it down eventually. But the t stat reads fine via thermal.gun
post #104 of 107 Old 07-18-2013, 02:49 AM
JMH21814
1997 XJ Cherokee
You may still have some air in your cooling system. I like to unscrew the temp sensor on the t-stat housing and fill until coolant comes out. Good luck!
JMH21814 is offline
post #105 of 107 Old 07-18-2013, 04:39 PM
sAe23
1995 XJ Cherokee
Gasket kit-70
T stat, coolant- 30
Paint-40
Misc. hoses- 20
Oil Pump-60
More to come....
Just an FYI, when I took my Jeep for a mud bath it cost $2300 (parts, labor and 3 yr warranty) to have my engine rebuilt.
sAe23 is offline
engine rebuild gsxjim XJ Cherokee Technical Forum 0 09-08-2010 12:43 AM
Engine rebuild 1091X XJ Cherokee Technical Forum 4 07-10-2010 08:06 PM
Gotta rebuild my engine. Should I wait and stroke it or rebuild it to stock specs. BorderC XJ/MJ Cherokee Non-Technical Forum 12 04-13-2010 08:33 PM
engine rebuild help!!! jesse24spd XJ Cherokee Technical Forum 2 03-31-2009 10:41 AM
engine rebuild amaple XJ Cherokee Technical Forum 8 02-28-2002 01:00 AM
