Rebuild Vs. New Engine - Page 4 - JeepForum.com
post #46 of 107 Old 06-30-2011, 11:36 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Thanks for the tips so far everyone. I just got an email from the guy with the 88 short block, only has 83k on it. Might be picking it up today! How much do these things weigh? Here's a picture of it as it sits.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #47 of 107 Old 06-30-2011, 01:27 PM
75SV1
I think the 4.0L is a bit heavy. I am thinking 350-400 lbs.
Tom
75SV1 is offline
post #48 of 107 Old 06-30-2011, 03:09 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Okay, that's fine. He has a lift, and I'll be putting it in the back of my jeep on a tire. I'll be grabbing it tomorrow morning. I'm stoked.
post #49 of 107 Old 07-01-2011, 12:45 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Got the engine! Pictures later. Said he used 20 50 oil in it?
post #50 of 107 Old 07-01-2011, 01:19 PM
75SV1
Unless he was trying to mask loose rings. It shouldn't have loose rings at that milage. Some people grew up that 20W-50 was racing oil. The drag racers used it, so it must be good for the street. I ran that weight in a 351W. It cost me about 2 mpg. I'd try Rotella. a 10w-40 should be good. Some are running 15W-40. I think I ran that in my RENIX 4.0L. It did OK. Rotella is formulated for diesels. The older ones. It should have a higher content of Zinc. That should protect your tappets and cam lobes. Also, I remember you are in Florida. So, higher temps, means a bit thicker oil. I'd probably gage it by what PSI of oil pressure the motor runs.
Tom
75SV1 is offline
post #51 of 107 Old 07-01-2011, 04:27 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Tom
That's funny you mention that, he said he uses to drag race back in the day. Said that's all he ran. Thanks for the input! Still haven't gotten it out of the back of the jeep yet, that should be a puzzle.
post #52 of 107 Old 07-02-2011, 02:07 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Here;s some pictures. I'm trying to find the bolt sizes for the back to mount it to the engine stand. If anyone knows, let me know. It's an '88 block.
post #53 of 107 Old 07-02-2011, 05:50 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Turns out that the top bolts are 3/8's and the bottom ones are 7/16's for the '88 block. Got it out of my jeep by myself with just an engine stand. That thing is a beast.
post #54 of 107 Old 07-02-2011, 08:15 PM
dave95_xj
1995 XJ Cherokee
I am thinking of building a stroker on the cheap. I can get a complete engine at the junkyard for 199.99$ plus a 25$ core charge...
dave95_xj is offline
post #55 of 107 Old 07-02-2011, 10:48 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Didn't realize I needed much shorter bolts, 4 or 5 inch will probably do. Getting grade 8 hardware for the top, too. First thing to do tomorrow.
post #56 of 107 Old 07-03-2011, 05:04 AM
Kevin108
The first thing I would do is hose everything down with Royal Purple or Purple Power or some crazy-strong cleaner and pressure wash it. That's what I did with mine and it made everything so much nicer to work on.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #57 of 107 Old 07-03-2011, 08:20 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
My buddy is in the pressure washing/ sealing business, so he has the real deal to get it cleaned up. Hot hot water and a serious pressure washer ought to do it.
post #58 of 107 Old 07-03-2011, 08:22 AM
FairlanePhil
FairlanePhil's Avatar
I would worry about getting water where you don't want it and getting rust.
I use cheap Autozone brake parts cleaner. Its the best degreaser you can use.
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #59 of 107 Old 07-03-2011, 05:03 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Fixed it up
ForumRunner_20110703_185949.jpg   ForumRunner_20110703_190039.jpg   ForumRunner_20110703_190150.jpg   ForumRunner_20110703_190222.jpg
post #60 of 107 Old 07-04-2011, 05:13 AM
Kevin108
I would worry about it if electrical things were hooked up. As it was, I put a cat food can over the throttle body and taped over the AC compressor and alternator.
Kevin108 is offline
engine rebuild gsxjim XJ Cherokee Technical Forum 0 09-08-2010 12:43 AM
Engine rebuild 1091X XJ Cherokee Technical Forum 4 07-10-2010 08:06 PM
Gotta rebuild my engine. Should I wait and stroke it or rebuild it to stock specs. BorderC XJ/MJ Cherokee Non-Technical Forum 12 04-13-2010 08:33 PM
engine rebuild help!!! jesse24spd XJ Cherokee Technical Forum 2 03-31-2009 10:41 AM
engine rebuild amaple XJ Cherokee Technical Forum 8 02-28-2002 01:00 AM
