Rebuild Vs. New Engine - Page 3 - JeepForum.com
post #31 of 107 Old 02-10-2011, 05:38 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by JEEPDAVIS View Post
91 to 99 will bolt right up, you wont have to change nothin.. 2000 and up will too i believe but ive heard there was somthin wrong with the block castings in 2000.. i dunno that forsure tho cause ive never owned one, thats just what ive read somwhere.
Block is okay on the 00-01, it is the 0331 cylinder head that has a problem and that existed only on the 00-01 XJ.
A known casting defect between cylinders 3-4. This defect makes this head more prone to cracking, especially upon an engine overheat.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #32 of 107 Old 02-10-2011, 06:12 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Cool. Let me just clarify. The alternator, a/c pump, power steering pump, and accessories will bolt onto any 91 or newer block without any modifications and will mount into my Jeep? And my 93 computer, intake and headers will fit as well?
Just trying not to make a 200 dollar mistake. Don't mean to be a bother.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #33 of 107 Old 02-11-2011, 11:32 AM
JEEPDAVIS
1989 XJ Cherokee
as far as i kno thats correct,,im pretty sure all of that is the same on all cherokees (except on non ho engines).. i kno they have different alternator or ac pump mounts on some yj's and tj's but i dont think they changed it on any of the cherokees.. dont quote me on that tho cause i dont claim to be an expert... i kno forsure tho that the computer, intake ,exaust manifold, water pump and power steering pump will bolt on... you might have to swap some mounting brackets for the alternator and ac pump, but they should also bolt right on ... someone correct me if im wrong
JEEPDAVIS is offline
post #34 of 107 Old 02-11-2011, 11:34 AM
JEEPDAVIS
1989 XJ Cherokee
i knew there was somethin wrong with them, just couldnt remember exactly what i read
post #35 of 107 Old 02-11-2011, 12:11 PM
smitty81
i just ordered a reman from marshall engines outa nebraska.. it was $1595 shipped, including the $395 core charge.. it came with a 3yr 100,000 mile warranty.. ive heard good things about them and i figured with as much driving as i do if any thing tears up on it ,it will do it befor the warranty is up.. but hopefully nothin will tear up (fingers crossed)... good luck
Im from nebraska and have been through their facility before.
I will vouch for Marshall motors. I have sold a number of them and had no problems with them. Their customer service is good too.
smitty81 is offline
post #36 of 107 Old 02-11-2011, 12:32 PM
Mikeand
Strokers dont last as long? Do it properly and youd have no problems, Ive got 100k on my stroker I built and no problems at all. Drive it everyday to work.
If spending money on an engine a stroker is the only way Id go now. $1500 would build you a pretty nice budget build..
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline
post #37 of 107 Old 02-11-2011, 12:46 PM
75SV1
Originally Posted by BassMasterCHS View Post
I tried searching for some info, but couldn't find it. Which years of 4.0's will fit into my Jeep? 92-96? Will I need to pull the computer from the donor too? I'll be getting an engine within the nest week. Just waiting on the tax return.
I'll be doing a write up once I start tearing apart the motor and rebuilding it.
91-95 will be a replacement. Other years will fit, or bolt in. The problem is the changes in the heads from different years. The 91-95 had an extra temp sensor in the head. It is on the driver side of the head. The 96 to 99 are basically the same head, except they don't have this port or hole for the temp sensor. So, you could use a short block from any year. Or at least up to 01, probably 02. I did use an '03 block and there was a porblem with the engine mount bosses.
Tom
75SV1 is offline
post #38 of 107 Old 02-11-2011, 01:05 PM
smitty81
mines a 99 and it has the 0331
smitty81 is offline
post #39 of 107 Old 06-26-2011, 05:10 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Would everything from my 93 motor bolt up to this 88 4.0 renix motor?
I've got the funds and time now to get a used motor, so if anyone local sees this and knows someone selling, let me know! Thanks.
http://tampa.craigslist.org/hdo/pts/2455863179.html
post #40 of 107 Old 06-27-2011, 01:22 PM
75SV1
The block should interchange. HEads bolt up to any 4.0L blocks. Using your head, then you can use your intake and exhaust header. I'd use yours or a new cam.
Tom
75SV1 is offline
post #41 of 107 Old 06-28-2011, 02:28 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Tom
Thanks for the help, I'm hoping it's still for sale. The prices locally for used engines are insane!
post #42 of 107 Old 06-28-2011, 04:11 PM
Kevin108
Originally Posted by cornbrizzle View Post
http://www.titanengines.com/index.php?main_page=index&cPath=9&zenid=ih63is45cl 7jgur5inhsfpvq67
Call and talk to Chuck , He will put a rebuild kit together for you , sell you a new motor, or he will rebuild your motor for you .
Brizzle
Great company! I bought my upgraded 0331 head from them.
Definitely keep an eye on Craigslist. If you have an Android phone, get the Craigslist Notifier. All the local junk yards wanted $1,000 for a used engine. After 6 months or so of my Heep sitting, I hit up Craigslist and found a 4.0/AW4/NP242 combo out of a 99 with 167,000 miles. The engine included all the accessories and sensors as well along with 90% of the wiring harness and the computer. $500 got it all. Dad and I just finished the install last night. He took it to get it inspected for me while I was at work today. I'm getting ready to head to his house to pick it up.
Good luck with your search!
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #43 of 107 Old 06-28-2011, 05:35 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Thanks man! Any tips or warnings as far as a build/removal/install goes?
post #44 of 107 Old 06-28-2011, 07:19 PM
Luke94XJ
1994 XJ Cherokee
Having swapped a motor 2 days ago: get some extensions for your socket sets, drop the trans mount, have a good jack possibly two. Take out the radiator, you can get the motor in with the radiator in place, but spending an hour pulling it out is better than maneuvering the engine for an hour. Pull the engine mounts with the motor, as they like to get in the way if you leave them in the bay. other than all that the bolts in the bell housing are the hardest part.
Luke94XJ is offline
post #45 of 107 Old 06-30-2011, 06:44 AM
Kevin108
I took off the header panel, radiator and fans. It gave us a lot more room to work.
You can set the power steering pump and AC compressor off to the side without disconnecting anything. Same goes for the starter.
Drop the engine in first with no cylinder head. That will let you tighten the top two bellhousing bolts from up top. When it's time to put the head on, bolt the intake and exhaust manifold to the head before setting it all in place.
The top two bellhousing bolts are inverse Torx. Their sizes begin with E and most people do not have these sockets in their tool kits. Most people swap these out for standard hex head bolts. You will also need a special tool to disconnect the fuel line if you opt to remove the intake and exhaust and drop them in with the head.
Cut the top threads off of the drivers side rear head bolt and relocate the ground strap. With the threads on top, it's difficult if not impossible to get a torque wrench on it.
If I think of anything else, I'll update this post.
Kevin108 is offline
engine rebuild gsxjim XJ Cherokee Technical Forum 0 09-08-2010 01:43 AM
Engine rebuild 1091X XJ Cherokee Technical Forum 4 07-10-2010 09:06 PM
Gotta rebuild my engine. Should I wait and stroke it or rebuild it to stock specs. BorderC XJ/MJ Cherokee Non-Technical Forum 12 04-13-2010 09:33 PM
engine rebuild help!!! jesse24spd XJ Cherokee Technical Forum 2 03-31-2009 11:41 AM
engine rebuild amaple XJ Cherokee Technical Forum 8 02-28-2002 02:00 AM
