Rear wiper switch Wiring.... - JeepForum.com
post #1 of 3 Old 11-10-2007, 04:23 PM Thread Starter
EG00TJ
EG00TJ's Avatar
1993 XJ Cherokee
Does anyone have a wiring diagram for the switch? When i bought my xj, the switch was cut out . So now that i bought a new one i have no clue of finding out which wires go where. Or can some one point me in the correct direction..
96 ZJ Longarm
Previous rigs : 96xj , 92 xj , 00 tj , 90 xj , 93 Longarm XJ
EG00TJ is offline
post #2 of 3 Old 11-11-2007, 12:10 AM
filluptrk
On my 00, if you are looking at the plug that goes to the switch there are 6 cavities. Top left is #1 bk ground #2 is on rt side bk/wt rear motor controller, bottom row left to rt #3 orange from fuse 6, #4 br/lg rear wiper motor control, #5 & #6 are br/pk both from fuse 22. Not sure that wiring is same from yours to mine. Do you have the plug that goes to the switch or was it cut? Not much room to work in there to redo a plug unless they cut it really close to the plug. Maybe hit a junkyard to see what you need. Phil
filluptrk is offline
post #3 of 3 Old 11-11-2007, 07:28 AM Thread Starter
EG00TJ
EG00TJ's Avatar
1993 XJ Cherokee
they cut it just behind the plug.. I will check it out more and get a better idea to see if its the same as yours. thanks
Edit: when u say PLUG, do you mean the back of the switch ??
96 ZJ Longarm
EG00TJ is offline
Rear wiper switch JGoad2 XJ Cherokee Technical Forum 10 06-25-2008 07:17 PM
Tempermental Rear Wiper Switch dakotajeep XJ Cherokee Technical Forum 4 10-08-2007 04:55 AM
Stock rear wiper switch bulb replacement? Freakshow XJ Cherokee Technical Forum 17 06-25-2007 11:10 PM
Rear washer and wiper switch not working, broken? cherokee Beater XJ Cherokee Technical Forum 0 02-26-2007 03:44 PM
97 rear wiper switch BigwillXJ XJ Cherokee Technical Forum 10 02-05-2006 01:43 PM
