Rear Wiper Fuse? - JeepForum.com
post #1 of 10 Old 10-21-2005, 07:46 PM Thread Starter
imtommorello
Rear Wiper Fuse?
I really need to 'disconect' my rear windshield wiper. i have to prevent power from getting to it.
you see, i have this electrical problem that when i turn on my headlights, my rear wiper starts 'wiping.' bug anoyance =(
anyone know if there is a fuse that i can just pluck out to make it stop working? if not a fuse, some other way i can prevent power from reaching the rear windshield wiper motor?
thanks in advance!
2000 Jeep Cherokee Sport
6 Cylinder Inline
As stock as they come =)
imtommorello is offline
post #2 of 10 Old 10-21-2005, 08:13 PM
tigerpaw580
1955 CJ2
unplug rear wiper
unplug the rear wiper , remove the hatch cover and unplug the harness at rear wiper motor.
tigerpaw580 is offline
post #3 of 10 Old 10-22-2005, 03:03 PM Thread Starter
imtommorello
sorry but, how do i unplus the rear wiper? im not sure what the hatch cover is?
6 Cylinder Inline
post #4 of 10 Old 10-22-2005, 04:03 PM
katarn444
katarn444's Avatar
He means the rear tailgate (hatch). If you pull the interior off there will be a connector on the motor that you can just unplug.
katarn
1989 Cherokee (A work in progress)
Up-country springs
New 18g floor
96 Grand Cherokee dual diaphram booster, master cylinder, PV
katarn444 is offline
post #5 of 10 Old 10-22-2005, 07:17 PM Thread Starter
imtommorello
sorry again, but, the tailgate is the handle you pull to open the back? sorry for asking another dumb question =(
6 Cylinder Inline
post #6 of 10 Old 10-22-2005, 07:24 PM
katarn444
katarn444's Avatar
Yes, I do not know if that is the best way to fix your problem but it is what the first person who posted was talking about. On the inside there will be a couple of screws, take those out and then just pull on the panel and it will pop off (atleast on my 89).
Did you look in the user manual for the fuse?
Maybe you should be looking for the problem that is causing the wiper to go on with the headlights.
Did you do a search, try here jeepsunlimited.com and naxja.com
katarn
Up-country springs
New 18g floor
post #7 of 10 Old 10-26-2005, 09:52 AM Thread Starter
imtommorello
craaaaaap.
my 2000 xj doesnt seem to have a place on the back to unscrew and get to the rear wiper. i unscrewed it...but its all for the little light above my license plate =(
no idea about a possible fuse?
6 Cylinder Inline
post #8 of 10 Old 10-26-2005, 02:42 PM
mh89xj
Dude you need to look on the inside
take the panel off the inside of your lift gate. this will expose the rear speakers and rear wiper motor.
89 XJ Laredo
222,000k
4-Speed Automatic AW4 Transmission
Dana M30 Front Axle Dana M35 Rear Axle
3.55 Axle Ratio
BDS 3" lift w/ 31x10.50 Pro Comp MT's
mh89xj is offline
post #9 of 10 Old 10-26-2005, 02:42 PM
ElPaca19
ElPaca19's Avatar
This has the fuse diagram. I think it's #21 or 22. I have aproblem with my fuse blowing everytime I run my rear wiper so I have replaced it alot. Pull the fusse and you should be good.
Ahh. Need the link
http://www.jeepforum.com/forum/showt...t=fuse+diagram
Mine: 2000 Black XJ Sport, D30 and 8.25 w/ Yukon 4.56's, 4.5" RE SF (plus a 1.75" Daystar spacer, 1.75" Teraflex shackle), OME LT Shocks, SJ SS, M.O.R.E Steering Box Brace, JKS Adj Track Bar, JKS Discos, AA SYE and TW CV DS, 15x8 Black Rock Krawlers, 33x12.5x15 Maxxis Bighorns, Bushwackers, ARB Bumper, 45 x 60 Surco rack, AJ's Super Rails, Class III rear hitch, 4 100w Hella 500's, Hella 550s, Hella Vision Plus, CB w/4ft Antenna, removable hood deck port, Borla cat back etc.
ElPaca19 is offline
post #10 of 10 Old 10-26-2005, 06:37 PM
Islandroaddie96
Islandroaddie96's Avatar
If the wiper is being activated by the headlights, then there is a good chance that the crossed connection is "downstream" (so to speak) of the fuse, which would mean that pulling it would have no effect. Your best bet is to temporarily pull the connector like described above, and then eventually find the problem and fix it.
Good Luck,
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline
Windshield Wiper fuse? tichick XJ Cherokee Technical Forum 6 10-17-2014 05:22 PM
rear wiper is popping the fuse jmpetre XJ Cherokee Technical Forum 2 12-29-2009 11:06 AM
Where is the wiper fuse / relay on a 1989 Cherokee abovenbeyond XJ Cherokee Technical Forum 3 07-11-2008 11:26 PM
Rear Wiper keeps blowing up Fuse ElPaca19 XJ Cherokee Technical Forum 6 11-09-2005 01:07 PM
Fuse for rear wiper ehunter20 XJ Cherokee Technical Forum 0 06-14-2004 08:44 AM
