Rear wiper doesn't press against glass - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Rear wiper doesn't press against glass
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 01-13-2010, 06:08 PM   #1
Powellae
I cleared some ice off the rear wiper on my '99 Cherokee and all of a sudden it doesn't press on the glass. The washer works and the wiper blade moves, but suddenly it doesn't press on the glass - so it won't clean anything.
When I was cleaning the ice off I thought I saw something fall off the wiper, but I couldn't find anything on the ground other than ice fragments.
I've tried lubing the pivot points, but the darn wiper just won't press against the glass. A search of this forum didn't reveal any similar reports.
Any ideas or experience with this problem? Thanks...
Powellae is offline   Reply With Quote Quick reply to this message
Unread 01-13-2010, 06:16 PM   #2
Islandroaddie96
Is the arm spring still good? Is it still there? Unless the arm is actually bent, the only thing it can really be is the spring.
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2010, 06:17 PM   #3
compcrasher86
Happened on my ZJ, the spring turned out to be broken/worn out. It was rusted and not pulling anymore. mine actually worked by lubing it up but I bet its easily replaceable
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2010, 06:56 PM   #4
LeftOfCenterXJ
1988 XJ Cherokee
Before replacing it try this:
Remove wiper arm assembly from motor shaft. Work the joint/hinge back and forth and lubricate it with some wd40.
Lots of times dirt and grime can get built up in the joint and cause too much resistance for the spring to pull the blade tight against the glass. In your case you may have some snow or ice built up in there. This is a fairly common problem on this type of design of rear wiper blade. I have had to clean mine out a couple of times.
Good luck
"Too weird to live, too rare to die"
2000 XJ Silver, 3", 31's DD
88 XJ Blue, 4.5", 33's, Project Build Thread
Originally Posted by Juju
It makes your trolling more credible to be grammatically correct. Lets everyone know you're a legitimate troll, not just one of those poser trolls.
LeftOfCenterXJ is offline   Reply With Quote Quick reply to this message
Unread 01-14-2010, 06:48 AM   #5
crosschecker
1995 XJ Cherokee
Good luck
X2
You probably got some grit stuck in the pivot which is preventing the arm from fully pivoting.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline   Reply With Quote Quick reply to this message
Unread 01-14-2010, 08:39 AM   #6
ccavin
Good luck
X3. I'm having the same issue right now. The hinge is just bound up a bit.
ccavin is offline   Reply With Quote Quick reply to this message
Unread 01-15-2010, 10:16 PM   #7
Powellae
Thanks...this gives me something to go after. Good chance it's some combo of grit and ice.
