rear windshield washer does not spray - JeepForum.com
post #1 of 6 Old 02-27-2011, 03:13 PM Thread Starter
qwain
I've a '98 Cherokee.
On the rear windshield I cannot get the fluid to spray. Any suggestion?
What is the wording you use to designate the fluid pump for the rear windshield (looking for it in Autozone without success...)
qwain is offline
post #2 of 6 Old 02-27-2011, 05:05 PM
polizi212
windshield washer pump. Takes the same one for front as the rear and both are on the washer fluid reservoir. advance lists it as part number 174347 ACI Windshield Washer Pump list for 19.99 each.
2000 Jeep Cherokee Sport.
polizi212 is offline
post #3 of 6 Old 02-28-2011, 09:16 AM
rugsucka
It is NOT the same pump for the front and rear wipers.
The two pumps are very close physically - same size, same plastic housing to attach to the reservoir, but have different electrical connectors. If you want to just remove and replace plug and play you will likely need to visit the Stealership.
The generic pump from the auto store(s) in my town had you LEAVE the seized OEM pump in place, then graft a couple of hoses to it and daisy chain the new pump to the old as the OEM pump has a 3/4" or so input press fit into the reservoir. You also would need to splice the wiring for power. This felt awfully ghetto and prone to failure. (says the guy with rubberized undercoating on his quarterpanels etc.)
I didn't like that idea since the space is tight up in the fender, I don't run fender liners which lets all sorts of roadwash up there, and I didn't wasnt to just zip tie a pump up there and hope it stayed. So I paid around 75 bucks for a MOPAR pump.
I checked and polizi212 is quoting an OEM style pump, (stupid Canada and our limited, yet high priced selection) I spent a week returning generic pumps, GRAND cherokee pumps, and finally buying a dealership pump for my '00 XJ.
HOWEVER: Before you replace any pump with any other pump, pull the upper pump from the reservoir (don't let the grommet fall into the reservoir or you will be removing the whole thing - ask me, I know) and test it with a couple small pieces of wire and your battery. If the pump whirrs it's fine, mine just did nothing. It is possibly the switch is busted in the dash. My switch is kind of broken - if you toggle it to wash it will spray and do the three sweep pass, but left on it doesn't have a 'delay' sweep anymore.
rugsucka is offline
post #4 of 6 Old 02-28-2011, 09:40 AM
hubs97xj
1997 XJ Cherokee
Test the pump and switch first (easy enough to do at the reservoir).
Go to autozone's website, punch in your vehicle info, and search for windshield washer pump, windshield washer, washer pump, or even just windshield, and it will be listed. Taap 8-695.
hubs97xj is offline
post #5 of 6 Old 02-28-2011, 09:50 AM
Shanker67
okay, just what? this shouldnt be that difficult.
go to autozone, ask for a winshield washer motor, they will give you one, it comes with a wire adapter, so it CAN be used for front or rear.
just did this like 3 months ago
Shanker67 is offline
post #6 of 6 Old 02-28-2011, 09:50 AM
Shanker67
^ what WAS all this? haha
Rear glass washer washer not working, pump or line problem? 1993jeep XJ Cherokee Technical Forum 9 11-16-2010 09:21 AM
Rear washer not pumping washer fluid. nujeepguy XJ Cherokee Technical Forum 11 10-25-2009 10:20 AM
rear windshield washer wojtizzlator XJ Cherokee Technical Forum 14 02-05-2007 06:36 PM
Windsheld Washer won`t spray CherokeeDude XJ Cherokee Technical Forum 1 04-12-2006 06:30 PM
Rear windshield washer isn't working Lore XJ Cherokee Technical Forum 6 11-16-2004 10:46 PM
