Rear window wont go back up - JeepForum.com
post #1 of 6 Old 01-23-2010, 06:50 PM Thread Starter
XJcruiser
I have a 99 4 dr XJ. The "Window Lock" button has never worked- only the driver can control the windows (fine by me.) Today, I put the windows down and now the rear passenger side window wont go up! I haven't started trying to fix it yet, just looking for a place to start. Is there a way to bypass the switch to see if everything else is good? Also, do I need to pull the door panel off to access the switches or can I pry them out of the door?
XJcruiser is offline
post #2 of 6 Old 01-23-2010, 06:55 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
The switch panel can be unscrewed from the door panel IIRC.
I would remove the affected windows door panel (3 minute job) and put a meter to the motor plug to see if it is getting power. Have someone else try the switch while you have the multimeter connected to the motors plug.
That will tell you right off if it is the motor or wiring etc.
You can also see if the window has come off the track etc too while the panel is removed.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 6 Old 01-24-2010, 03:27 PM Thread Starter
XJcruiser
Okay, done. The window is on track and but there is no power to the motor. Time for a new switch?
post #4 of 6 Old 01-24-2010, 03:50 PM
leftlanetruckin
XJ on 37's
Now you need to find out if the switch panel on the drivers door switch panel is putting the power out or not.
If it is, you have a break in the wire somewhere or the switch on the affected door is robbing the power.
If not, then you could be looking at the switch panel on the drivers door, or a possible wiring issue there.
Let me see if I can find the diagram of that switch panel for my 98, should be the same I hope...
Did you manage to raise the window again by giving the motor 12 volts and a ground?
Martin
post #5 of 6 Old 01-24-2010, 03:57 PM
leftlanetruckin
XJ on 37's
Test for continuity and power following the diagrams below. If you cannot figure them out let me know and I will walk you through it.
Martin
post #6 of 6 Old 01-24-2010, 04:04 PM
vnemous
Hey
When I bought my 99 xj the windows would sometimes work and sometimes not. I did the modification to the window lock out button and never had another problem with them. Use the search engine to find this modification. It might fix your problem.
vnemous is offline
pass window wont roll down jbonez2222 XJ Cherokee Technical Forum 0 10-29-2009 05:45 PM
window electric wont go back up..... nickXJcherokee XJ Cherokee Technical Forum 4 06-11-2009 08:21 AM
Window tint on the back window?? marinefreak200 XJ/MJ Cherokee Non-Technical Forum 16 05-23-2009 09:51 PM
manual front window wont go up skier518 XJ Cherokee Technical Forum 1 04-17-2008 02:56 PM
Window Wont Roll Back Up....What Now?? Mud Machine XJ Cherokee Technical Forum 2 05-04-2007 02:10 PM
