Rear whell bearing replace on D35 - JeepForum.com
post #1 of 4 Old 11-05-2006, 06:12 PM Thread Starter
Catalina
Does anyone have or know of a write-up on how to replace wheel bearing on a D35 for '94 XJ? I just finished the front hub replacements this weekend and noticed that the rear wheels have a sloppy feel too. I'm a bit lost on where to start and how to finish this one. Thanks for any help!
Catalina (aka vmaxbt)
Livonia, Michigan
'05 Unlimited, XM Radio
2.25" 4WC BB w/ Skyjacker Hydros
32x11.5x15 BFG AT KO's w/ Spidertrax spacers
'94 XJ, 3" lift, 29" BFG AT KO's, Skyjacker shocks
Catalina is offline
post #2 of 4 Old 11-05-2006, 07:04 PM
tangofox007
I did mine several years ago. Pretty simple job, but an arbor press is essential. My axles did not have c-clips, so I did not have to open the differential. Just remove the four nuts behind the and the axles came right out. The bearing cups came out easily, too.
I seem to remember that the Timken bearings that I bought came with fairly detailed instructions.
tangofox007 is offline
post #3 of 4 Old 11-05-2006, 07:18 PM
stevenaa
Some in and out play is normal. you need to jack it up and see if the wheel has play up and down.
stevenaa is offline
post #4 of 4 Old 11-05-2006, 07:28 PM
AZ Jeff
2014 JK Wrangler
Agreed. You use the term "sloppy feel", which is pretty vague. Sloppy in WHICH DIRECTION is the key. Axial play (in the direction of the axle shaft) is NORMAL. Radial play (perpendicular to the shaft axis) is NEVER acceptable.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
How to replace front output bearing on a NP231 transfer case? oldford XJ Cherokee Technical Forum 6 07-01-2011 06:55 AM
Rear wheel bearing/axle shaft bearing replacement? kadetklapp XJ Cherokee Technical Forum 4 09-02-2008 01:06 PM
Wheel bearing going out, how tough to replace? LXguy XJ Cherokee Technical Forum 6 08-20-2006 11:29 PM
any tech. info. on changing rear axle bearing (pinion bearing)??????? cg2xj XJ Cherokee Technical Forum 1 07-20-2006 10:45 PM
Replace Wheel Hub and Bearing 360 bucks!! Renegade_Rick XJ Cherokee Technical Forum 4 02-20-2006 08:31 PM
