Rear spring rebuild centering pin questions - JeepForum.com
post #1 of 3 Old 08-26-2013, 09:14 AM Thread Starter
nhurto
I'm rebuilding my rear springs after having the centering pin shearing on the trail a few weeks ago. I reassembled the springs and realigned the centering holes. This shows where I am currently in the rebuild (I know the centering pin is upside down but it was the easiest way to get the leafs aligned):
My question is to clarify whether or not I should bore out the hole in the spring plate attached to the axle (yellow circle) to match the size of the centering pin head (red circle)? Is there anything else I need to consider in putting everything back together?
Thanks,
Nate.
nhurto is offline
post #2 of 3 Old 08-26-2013, 09:30 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I would use a grinder on the head of the centering pin to match the size of the spring perch. Pins are much easier to replace than the perch. I've done it before, a bench grinder makes quick work of it.
Randonexplosion is offline
post #3 of 3 Old 08-26-2013, 01:25 PM
M35A2
1995 XJ Cherokee
Use a c-clamp to hold the pacs together and flip the center bolt around. X2 on the bench grinder for re sizing the locating dowell.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
