Rear Main Seal Replacement - JeepForum.com
post #1 of 14 Old 10-16-2003, 12:40 AM Thread Starter
RockinXJ
RockinXJ's Avatar
Ok, so last Friday I decide I'm going to replace my rear main seal to get my XJ to stop leaking oil. I bought the rear main seal, a new oil pan seal, and some new oil to go in after all is complete. I took out 28 bolts to remove the oil pan, removed the rib plate that ties all of the main bearing caps together, removed the rear main bearing cap, removed and replaced the lower portion of the seal in the bearing cap, and I noticed something while removing the upper portion of the seal from the block. The area that the rear main seal contacts on the crankshaft was not smooth like it should be. I assume it should be as smooth as glass like the rest of the crankshaft, but the contact area has minute ripples in it just where the seal touches. Is this the way it should be? After properly re-installing everything and getting the bolts torqued to specs, I took it for a test drive and all was good except for a minor drip compared to what it was doing. I am thinking it is still leaking due to the ripple in the contact surface. What would cause such a thing?
Also, while I was under the Jeep turning wrenches, I noticed I had a transmission fluid leak where the metal strap holds the two lines to the bottom of the transmission near the starter. I further investigated the leak by removing the strap, and low and behold, the strap had worn a hole in the side of the tranny line after 192,400 miles. My fix was to cut about an inch out of each of the two lines and replace the setion removed with a compression fitting. After about 400 miles on it, it is not leaking, and still sending transmission fluid to the cooler up front as it should.
If you have any input on either subject, please feel free to post.
Thanks
If you light a fire for a man you'll keep him warm for a day, but if you light a man on fire, you'll keep him warm for the rest of his life!
I ♥ Transitive Pictograph Verbalizations
RockinXJ is offline
post #2 of 14 Old 10-16-2003, 10:46 AM
Tumbleweed
I'm getting ready to do the same job, as my 91 with 110,000 is seaping and it hits the exhaust. so I read your post with interest.
No, the crank journal should be smooth everywhere, the bearing needs a smooth surface and the rubber seal won't follow a rough surface. Replacing the seal will help but not fix this leak. Unfortunately this can only be cured by taking the crank out and having it cleaned up or replaced. You may find it easier and cheaper to keep replacing the seal when the seaping becomes a full on leak, until you are ready to do a rebuild.
Sorry for the bad news, but that's my understanding of the rubber/ steel sealing concept. If I'm wrong I don't mind being corrected.
The lesson to the rest of us here is that allowing a failed seal to remain in place may end up doing more damage. I just got this XJ and both the front and rear crank seals are seaping, now I'm a little more motivated to get if fixed. I hope I don't find any suprises.
How long would you estimate you spent on the job. 4 hrs? 6?
Also what did you need to do to get the axle low enough for the oil pan to come out. I'll be doing this in my driveway, and could use any input to reduce the time it takes to get in there. I've read my chilton manual and I hope it's not too much of a PITA.
Regards,
Ethan
91 Laredo
Stock, 4.0L, AW4, Selec-trac.
Tumbleweed is offline
post #3 of 14 Old 10-16-2003, 12:48 PM
XJMark
XJMark's Avatar
You'll have to keep changing them only if you use the wrong parts. Getting a plain seal will get you a seal intended for a fresh rebuilt engine with a smooth crank.
The groove happens because the oil makes the seal turn hard as a rock. This in turn causes the seal to groove the crank seal surface. There is supposed to be a problem solver type rear main seal that has a double lip that fixes leaks due to grooves. The second lip makes contact with the fresh ungrooved surface of the crank, if I'm not mistaken it also has a tad more depth for a better fit against a now smaller crank diameter.
Also those with 3" or more of lift should have no problem removing the oilpan due to axle clearance. That's the distance all the manuals usually tell you to drop the front axle.
Mark
XJMark is offline
post #4 of 14 Old 10-16-2003, 02:19 PM
iowagoneer
When I did the job on my unlifted '89, disconnecting the swaybar links let the axle drop far enough to get the pan off. (What a splendid time that would be to install quick disconnects.) I pushed the axle down just a bit more with a bottle jack. The PITA part of the job on mine was getting the top half of the seal out of the block. Never could budge it, and finally decided it was best to leave it alone rather than risk breaking/clobbering it. Replacing just the lower half bought me a year of practically drip-free driving.
LarryJ
iowagoneer is offline
post #5 of 14 Old 10-16-2003, 11:30 PM Thread Starter
RockinXJ
RockinXJ's Avatar
Regards,
Ethan
I'd say probably about 8 hours, but I was working slowly, and I had to repair the tranny lines while I was underneath it, so take that as you will. Basically, you drain the oil, drop the oil pan, remove the rib plate bolted to the main bearing caps, remove the rear main bearing, drive the upper part out with a punch, and pull the lower part out with a small flat bladed screwdriver and some needle nose pliers.
The most time consuming part was removing the oil pan. I have a 3" lift with adj. LCA's that let the axle droop enough to pull the pan out. I had jack stands under the "frame" too.
RockinXJ is offline
post #6 of 14 Old 10-16-2003, 11:32 PM Thread Starter
RockinXJ
RockinXJ's Avatar
Mark
I am interested in this main seal. Do you have any idea where I can get one? I wouldn't mind doing it again if it will stop my leak.
RockinXJ is offline
post #7 of 14 Old 10-17-2003, 01:47 AM
XJMark
XJMark's Avatar
Stealership for sure (not that big a price difference). The double lip is designed for replacing the stock hard as a rock single lip that caused the leak. It seals in two places that are offset from the original seal area.
You may be able to get it at NAPA or another well stocked outlet also. It will be listed as a "supersedes part#nnnn" probably under the Chicago rawhide or Fel-Pro brands.
Mark
XJMark is offline
post #8 of 14 Old 10-17-2003, 06:41 AM
Tumbleweed
Great info, thanks. I heard of the double lip seal but wasn't sure what it was for.
91 Laredo
post #9 of 14 Old 10-18-2003, 04:11 PM
CLB
CLB's Avatar
i know exactly what you mean about it seeping out onto the exhaust, i was smokin so bad but i thought it was kinda funny, this is the only mod that i didnt have time for seeing as how i go to school, job and football so i took it into the shop, so its actually in there right now, its coming out tomorrow. im gunna ask the mechanic about the work done tho so i can get a good idea for it. hes actually fixing my door and a relay in my heater too. so my xj is gunna be ship shape
91 XJ Laredo
6.5" Rustys, RR Adj Trac Bar, RE Adj UCAs/LCAs, DT3000, M.O.R.E steering box brace, Rancho steering stabalizer, custom cone intake, Poweraid TB spacer, home-brew roof rack, lights everywhere, +10 HP Jeep Seatbelt pads, hole in the fender from previous snorkel, plus a lot more crap
RJC #42
CLB is offline
post #10 of 14 Old 05-26-2010, 07:01 PM
SpydrGP
looks different...
I am working on my '96 XJ and while doing the RMS I found a plate attached to all the crank bearing caps.
Can I remove it without messing up the other caps??
SpydrGP is offline
post #11 of 14 Old 05-26-2010, 08:44 PM
303_XJ
Nice thread revival
Wanna come by Golden and show me a thing or two about replacing mine?
Colorado Jeep Club Member # 208
303_XJ is offline
post #12 of 14 Old 05-27-2010, 08:29 AM
xjbrian
Yes. You have to remove it. I did mine a couple of months ago.
xjbrian is offline
post #13 of 14 Old 12-06-2011, 09:18 PM
logem
This is my first step towards reviving my 2001 4.0 liter manual. I have numerous issues, but this is the easiest and first one to take care of, in my mind. Thanks to all who have provided information in this thread over the years.
All I need now are part numbers for:
Mopar OEM double lipped rear main seals
oil pan gasket for 2001 TJ
special OEM gasket sealant for oil pan gasket.
Thanks,
Mike
2001 Sahara, 5 Speed Manual with About $10K in upgrades.
logem is offline
post #14 of 14 Old 12-07-2011, 08:54 PM
EricsXJ
The Post man
EricsXJ's Avatar
Not sure the part number but its probably the same one as the '00 and '01 XJs which is different than the earlier ones. I found that for this particular seal it was cheaper to get the Mopar seal from the dealer than the Felpro seal was at Oreilly's.
Felpro one-piece seal at any parts store
Not sure on that one as I used RTV instead. It worked fine for me.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
2001 Rear main seal 'tabs' on replacement seal, but not OEM (did search) akxj01 XJ Cherokee Technical Forum 2 11-12-2008 07:22 PM
Rear main seal replacement ? JeepJinx XJ Cherokee Technical Forum 5 08-18-2008 04:40 PM
rear main seal replacement problem motu1983 XJ Cherokee Technical Forum 5 07-27-2008 01:01 PM
Main seal replacement... RamboPants XJ Cherokee Technical Forum 2 04-04-2007 05:31 PM
rear main seal replacement....update Greggor XJ Cherokee Technical Forum 0 10-24-2004 01:27 PM
