rear main seal/oil pan *&%#$$#$% - JeepForum.com
post #1 of 14 Old 05-30-2006, 11:45 AM Thread Starter
marcocor
2000 xj I6 trying to do my iol pump and rear main seal and I can not for the life of me get the oil pan out can some one give me a tip before I snap:
marcocor is offline
post #2 of 14 Old 05-30-2006, 11:52 AM
B-mac
what do you mean by out: bolts, actually pulling it off the block or finding room above the axle to get it out of the way
B-mac is offline
post #3 of 14 Old 05-30-2006, 11:54 AM Thread Starter
marcocor
to get to clear the axle all the bolts are out
2000 xj classic I6 auto 2" budget boost 30" tires Canadian police package
marcocor is offline
post #4 of 14 Old 05-30-2006, 11:55 AM
XJ4oh
1997 XJ Cherokee
Jack the Jeep up by the unibody, or "frame" somewhere up front. That will create some more suspension travel and give more room.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #5 of 14 Old 05-30-2006, 11:57 AM Thread Starter
marcocor
i have done that still will not clear
marcocor is offline
post #6 of 14 Old 05-30-2006, 12:10 PM
FleXJ the Kid
sounds like a good point to install a lift. I have 5 inches up front and i still had to jack the frame up to get the pan off (did the rear main seal yesterday). i would try jacking the frame up as high as possible if that is still not enough, try removing the swaybar because that limits suspension droop a lot. if that doesn't work remove the track bar. if you do end up having to remove the axle, you should definetly consider installling a lift kit because you will not want to drop the axle again (kill two birds with one stone)
'88 Cherokee Pioneer
Rebuilt 4.0 litre (bored .030 over)
Homemade cold-air K&N cone filter
Empty cat, Flowmaster
Rubicon Express 4.5" with leaves
BA-10 Tranny/NP 231 TC
Non-Disconnect Dana 30, Dana 44 regeared to 4.10
33x12.5 BFG MT's on Black Rock Krawler rims (3.75" BS)
FleXJ the Kid is offline
post #7 of 14 Old 05-30-2006, 12:24 PM
B-mac
to make mine easyer i just took the front axle out it let me clean all the oil off that was leaking in i painted mine and switched the fluid. it wasnt that hard especially if you have another vehicle to drive and a friend to help
B-mac is offline
post #8 of 14 Old 05-30-2006, 01:58 PM
AZ Jeff
2014 JK Wrangler
Sway bar links off? Shocks disconnected? Front DS removed?
As a last resort, control arm bolts loosened (but NOT removed) at both ends? (If you do this, be sure to put the XJ back on the ground under it's own weight before retightening these bolts)
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #9 of 14 Old 05-30-2006, 04:01 PM
Twsty
1988 MJ Comanche
ive heard you need to remove the steering stabilizer.
1988 MJ 4.0/D60/14b/5.38/42s/PSC hydro
1995 XJ 4.0/AW4/231/JCR sliders/235s on KJ 16" wheels
1996 F350 PSD/ZF5, 375hp/692ftlbs
Twsty is offline
post #10 of 14 Old 05-30-2006, 04:31 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
I disco'ed my lca's and swaybar. I also loosened my uca's. This gave me enough room to replace the pan, which can be more frustrating than removing it.
Good luck
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #11 of 14 Old 05-30-2006, 06:07 PM
600dollarXJ
The Haynes Manual says to take the scatter shield off the transmission, and take the steering stabilizer off. Thats what I did on mine (2wd though) and the pan practically fell out.
88 Jeep Cherokee - 4.0 - AX15 - 231 - d30 disconnect with welded spiders - d35+aussie
1998 Suzuki TL-1000R
600dollarXJ is offline
post #12 of 14 Old 05-30-2006, 09:23 PM
mr_frenchy
Factory Service manual says this:
OIL PAN
REMOVAL
(1) Disconnect the negative battery cable.
(2) Raise the vehicle on hoist.
(3) Drain the oil.
(4) Remove the oil pan lower cover (Fig. 45).
(5) Remove the bolts from oil pan. Remove the 6
bolts that are on the inside of the oil pan.
(6) Remove the oil pan.
'75 CJ5, SOA, 36" buckshots, Warn 9000i upfront, 304 V8
In the Bible some where it says that if you sell your Jeep to buy a honda, you'll go to hell. It's somewhere in the back, near the maps.
mr_frenchy is offline
post #13 of 14 Old 05-30-2006, 10:03 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
Not sure if it could help but my trick on a ford 302 on a F150 was to drop the pan as far as it would go the unbolt the oil pum and drop it in the pan. For installation I just put the new pump in the pan and reverse ordered everything.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #14 of 14 Old 05-31-2006, 10:36 AM Thread Starter
marcocor
thanks for the help .what a JOB to just pull the pan
marcocor is offline
2001 Rear main seal 'tabs' on replacement seal, but not OEM (did search) akxj01 XJ Cherokee Technical Forum 2 11-12-2008 07:22 PM
Rear main seal tgreenwood XJ Cherokee Technical Forum 9 04-03-2008 09:11 AM
Rear Main Seal jatarro XJ Cherokee Technical Forum 3 02-17-2007 09:09 AM
rear main seal iwishihad1 XJ Cherokee Technical Forum 3 02-16-2007 08:21 PM
rear main seal wedgewest XJ Cherokee Technical Forum 5 04-24-2002 03:11 PM
