2000 xj I6 trying to do my iol pump and rear main seal and I can not for the life of me get the oil pan out can some one give me a tip before I snap::brickwall
sounds like a good point to install a lift. I have 5 inches up front and i still had to jack the frame up to get the pan off (did the rear main seal yesterday). i would try jacking the frame up as high as possible if that is still not enough, try removing the swaybar because that limits suspension droop a lot. if that doesn't work remove the track bar. if you do end up having to remove the axle, you should definetly consider installling a lift kit because you will not want to drop the axle again (kill two birds with one stone)
to make mine easyer i just took the front axle out it let me clean all the oil off that was leaking in i painted mine and switched the fluid. it wasnt that hard especially if you have another vehicle to drive and a friend to help
Sway bar links off? Shocks disconnected? Front DS removed?
As a last resort, control arm bolts loosened (but NOT removed) at both ends? (If you do this, be sure to put the XJ back on the ground under it's own weight before retightening these bolts)
I disco'ed my lca's and swaybar. I also loosened my uca's. This gave me enough room to replace the pan, which can be more frustrating than removing it.
The Haynes Manual says to take the scatter shield off the transmission, and take the steering stabilizer off. Thats what I did on mine (2wd though) and the pan practically fell out.
OIL PAN
REMOVAL
(1) Disconnect the negative battery cable.
(2) Raise the vehicle on hoist.
(3) Drain the oil.
(4) Remove the oil pan lower cover (Fig. 45).
(5) Remove the bolts from oil pan. Remove the 6
bolts that are on the inside of the oil pan.
(6) Remove the oil pan.
Not sure if it could help but my trick on a ford 302 on a F150 was to drop the pan as far as it would go the unbolt the oil pum and drop it in the pan. For installation I just put the new pump in the pan and reverse ordered everything.
thanks for the help .what a JOB to just pull the pan
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
