Rear leaf springs.. - JeepForum.com
post #1 of 17 Old 12-08-2007, 06:13 PM Thread Starter
dubaudi
Rear leaf springs..
So after the $1700 disaster I just went through to replace the head, radiator, and every part in between on my 2000 XJ.....plans for a suspension lift may have to wait until spring.
But lately I've noticed my rear suspension is sagging lower than it used to. If I have even one passenger in the back, it looks like a lowrider back there! Is there a relatively inexpensive solution for this? I basically want it to ride maybe 2 inches higher, but not so high that it looks awkward in comparison to the front.
I remember reading somewhere about a replacement leafs that we slightly higher than stock, but searched and couldn't find anything.
Anyone have any ideas?
Thanks!
-Tom
dubaudi is offline
post #2 of 17 Old 12-08-2007, 06:15 PM
boondocksaint
boondocksaint's Avatar
1995 XJ Cherokee
Location: school - Campbellsville, KY; home - Oviedo, FL
If you want to replace the entire leaf pack, but don't want to lift, these might work for you:
http://www.quadratec.com/products/56010_11.htm
David
White 95 XJ - Jacked up and abused
White 98 XJ - Stock and babied
boondocksaint is offline
post #3 of 17 Old 12-10-2007, 08:13 AM Thread Starter
dubaudi
Do you know if those actually raise the car at all or leave it at stock height? Technically right now I'm sure I'm a bit lower than stock height since they're sagging....but I don't remember what stock height looks like...lol
dubaudi is offline
post #4 of 17 Old 12-10-2007, 08:26 AM
jeepfever87
1987 YJ Wrangler
At least your disaster happened before you spent a lot of money, mine happened right after the lift. I know a few people that used helper springs for a small boost.
1999 XJ Sport- 4.0, AW4, np231 w/ Tera SYE, Rusty's 4.5", 33x12.5 tsl's
1987 Wrangler- SOA, 44 front, 9 inch rear, mustang 5.0, 38x13 swampers
1993 grand- 5.2, auto, IRO 3.5" on 32 bfg muds
Originally Posted by Cherokeegrrl
What's the point in having adjustable headrests if ya strap them down? (It's like a girl doing that to her um ... dubble_D's. )
jeepfever87 is offline
post #5 of 17 Old 12-10-2007, 08:35 AM
boondocksaint
1995 XJ Cherokee
Those are stock springs, so they'll take it back to stock height. They're also the HD springs, so they should last longer...
David
post #6 of 17 Old 12-10-2007, 09:18 AM Thread Starter
dubaudi
Cool, thanks for the info!
One thing I've noticed when I look at other stock XJ's on the road is that it seems like the "Sport" models had a slightly higher ride height than the Limiteds. Can this be verified? Sometimes I'll see an XJ with a perfect, even, stout ride height, then there will be one right next to it with the rear end sagging like mine. From what I can tell, the fronts look to always be around the same height. I thought maybe the Ltd models came a little lower than the Sports but I haven't been able to verify that.
dubaudi is offline
post #7 of 17 Old 12-10-2007, 09:24 AM
boondocksaint
1995 XJ Cherokee
nope. all came w/ the same springs (as far as I know), except for the Up-Country package, which had about a 1" lift.
David
post #8 of 17 Old 12-10-2007, 09:26 AM
dakotajeep
dakotajeep's Avatar
The Up Country package was and inch higher but other than that they are all the same.
FYI the Quadratech HD packs, according to users on here, may give you anywhere from a half inch to an inch over stock height.
Beat me to that.......
2006 WK 4.7 Laredo 4x4 Stock...looking for Mod's
*SOLD* 1998 XJ 4.0, Modified Rock Lizard Homebrew lift (about 1.5 inches), 215/75 BFG AT's, Dynomax muffler, Firepower Ignition Kit w/Champion plugs, Sylvania headlamps (best bang for the buck)
dakotajeep is offline
post #9 of 17 Old 12-10-2007, 09:41 AM
SuperStreetJeep
SuperStreetJeep's Avatar
1993 XJ Cherokee
since you plan on lifting later 2" blocks could get you by until you buy a complete lift and as long as you end up getting full leaf packs, it shouldn't cause any damage
Think Your Jeep Is Fast??? Click Here!!!
SuperStreetJeep is offline
post #10 of 17 Old 12-10-2007, 09:49 AM Thread Starter
dubaudi
I was thinking about doing that, but I travel a lot with the car, especially back and forth to Vermont, and I usually have some luggage or a passenger or two with me. I know it would "look" right with the 2 inch blocks, but I'm not sure how long it'll be until I lift it so I think I may just get the HD leafpacks so that at least I know I won't be doing any harm to those weak stock leafs anymore.
Does anyone have a before/after picture with those Quadratec HD packs in?
dubaudi is offline
post #11 of 17 Old 12-10-2007, 09:55 AM
boondocksaint
1995 XJ Cherokee
It might've been just my luck, but I had a terrible time w/ my blocks. Of course, I left them in for about 9 months, as well. I guees if you leave em in for 3-4months you might be Ok.
David
post #12 of 17 Old 12-10-2007, 09:57 AM
boondocksaint
1995 XJ Cherokee
This is mine w/ flat springs, 2" blocks, and 235's...
David
post #13 of 17 Old 12-10-2007, 03:13 PM
AMXJ
2010 WK
Thanks!
-Tom
Not the best solution but a quick fix, you could install some air shocks for now. That way you can adjust your ride height.
Add-A-Leafs will raise it up but they will make it ride like crap!
Dennis
AMXJ is offline
post #14 of 17 Old 12-10-2007, 03:40 PM
boondocksaint
1995 XJ Cherokee
Dennis
From what I understand, AAL's are supposed to retain the stock ride...maybe not, though.
David
post #15 of 17 Old 12-10-2007, 07:23 PM
Just4Fun111
1990 XJ Cherokee
Whats this thing I here about Dakota springs in a jeep? It seems to be with 3" lifts or is it for stock?
Just4Fun111 is offline
Add-a-leaf vs. rear leaf springs beaucaldwell XJ Cherokee Technical Forum 6 10-14-2009 08:52 PM
Rear leaf springs CherokeeTrav XJ Cherokee Technical Forum 3 12-02-2008 09:41 PM
Rear leaf springs zatch83 XJ Cherokee Technical Forum 8 01-11-2007 03:35 PM
Rear Leaf Springs Ranger350 MJ Comanche Technical Forum 23 05-28-2005 02:02 PM
rear leaf springs JeepCreep87 XJ Cherokee Technical Forum 8 01-11-2005 10:13 AM
