Rear leaf springs - JeepForum.com
post #1 of 9 Old 01-10-2007, 08:53 AM Thread Starter
zatch83
1992 XJ Cherokee
Rear leaf springs
I have a 92 XJ Laredo with a sagging rear end. The leaf springs are pretty much flat. I'm afraid they might start curving downward. Any ideas how to fix this? Would an add-a-leaf kit be sufficient? I have been pondering a 3" lift for a while, but don't exactly have any money. Aww...the college life!
zatch83 is offline
post #2 of 9 Old 01-10-2007, 08:58 AM
ddoffroad
ddoffroad's Avatar
Rear leafs sag hardcore on hi-mi XJ's....You could AAL it if you want, but if you're gonna take everything appart you mite as well do the lift. You could get a 3" with shocks for like $400 or so...
-ddo
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad:
My XJ site:
My Old XJ Site:
ddoffroad is offline
post #3 of 9 Old 01-10-2007, 09:14 AM
bee guz
leaf sagging
Go to a spring shop, and ask them to add a leaf, they can add one leaf to the bottom and it will correct, you springs, or lift it a little it all depends what you want.
I had a YJ with a plow and the front end used to come down to meet the plow instead of the plow going up, I had one leaf added at the spring shop, new U bolts leafs and labor was 100 bucks, no rust in my eyes priceless...
bee guz is offline
post #4 of 9 Old 01-10-2007, 03:34 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Zach,
Check out this link for some ideas on a cheap lift. http://www.rocklizardfabrications.co...dget_boost.htm . You can drive for a long time on sagging springs. Find a U-Pull-It or Pick and Pull self service junkyard, a complete leaf spring is around $12.00. New replacement springs are online at www.quadratec.com
CJ7-Tim is offline
post #5 of 9 Old 01-11-2007, 09:19 AM
xjman4life
xjman4life's Avatar
I have rear springs out of a 96 i wanted to get rid of, i was going to put them in my 89 but i'm getting a lift instead. Might need new bushings cause they were cut out with torches and the junkyard slightly burned them. I will let u have them for a certain fee. Email me at bpsnknm01@msn.com if your interested. Thanks.
xjman4life is offline
post #6 of 9 Old 01-11-2007, 09:22 AM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Dont use a new shackle. It will just make it worse. I tried it and it inverted mine, so i ended up having todo a 3 inch lift.
Arcticcat843 is offline
post #7 of 9 Old 01-11-2007, 10:05 AM
MrShaft696
go the the junkyard and get some leafsprings to add. you need some 2.5" wide ones, the s10s and dakotas work fine
96xj 4.0 5sp 4.5"spartan/aussie locked, 4.56 gears 35"KM2's 98 5.9 zj 4" lift 33's..99 xj 235's
MrShaft696 is offline
post #8 of 9 Old 01-11-2007, 02:27 PM
JeepNFla
I had the same problem on mine about a year ago. As I was getting ready for a road trip, I asked my trusty local wrench what he thought would be a good solution and on his advice I put some air shocks on. Now, I can adjust the rear end level depending on the load. So far so good! If you put the shocks on yourself, they'll run about $60 for the pair.
'97 Cherokee Sport, 4.0 I6
4x2
Stock
JeepNFla is offline
post #9 of 9 Old 01-11-2007, 03:35 PM
law.74
Originally Posted by JeepNFla
...I put some air shocks on. Now, I can adjust the rear end level depending on the load. So far so good! If you put the shocks on yourself, they'll run about $60 for the pair.
Any pics? Are you refering to "shocks" or "lift bags"?
law.74 is offline
Add-a-leaf vs. rear leaf springs beaucaldwell XJ Cherokee Technical Forum 6 10-14-2009 08:52 PM
Rear leaf springs CherokeeTrav XJ Cherokee Technical Forum 3 12-02-2008 09:41 PM
Rear leaf springs.. dubaudi XJ Cherokee Technical Forum 16 12-10-2007 08:59 PM
rear leaf springs newAT4wheeling XJ Cherokee Technical Forum 5 07-25-2005 11:16 AM
Rear Leaf Springs Ranger350 MJ Comanche Technical Forum 23 05-28-2005 02:02 PM
