Rear Frame rail..."scary" - JeepForum.com
post #1 of 15 Old 06-05-2013, 08:43 PM Thread Starter
TonyPgh
Here's some photos of my right rear frame. I would like to know who inspected this vehicle the guy just sold me last week. The stickers are only two months old. It didn't rot out that fast.....Is this dangerous?
Looks like they screwed some metal over the rear frame rail. This scared me when I saw it.
TonyPgh is offline
post #2 of 15 Old 06-05-2013, 08:59 PM
dmill89
1995 XJ Cherokee
That looks like thin metal held on with sheet metal screws, not good. The proper way to repair this would be either with thick plates welded on or better yet cut out and replace the bad section (weld in a "new" rail section). I'd probably pull the screws and see what's underneath.
As for inspection this is probably a legal repair, but certainly not a good one. The PA inspection regulations (see below) only specify that the frame be in "solid" condition (which is open to interpretation by the shop) and that repairs are not made with tape, tar paper or cloth, or in a "temporary manner" (again open to interpretation by the shop). So sheet metal is likely legal so long as the frame is not rusted so bad that it has no structural integrity.
From PA inspection procedures subchapter "E"
(5) Inspect the vehicle frame and REJECT
IF
one or more of the following apply:
(i) The vehicle frame is not in solid
condition.
(ii) The repairs are made with tape, tar
paper or cloth, or are made in another
temporary
manner.
(iii) The frame components are missing,
cracked, rotted, or broken or are in
deteriorated or dangerous condition.
(iv) Body mounts do not hold as required.
(v) A body mount is broken, cracked,
deteriorated or missing.
(vi) The difference in the body floor and
the top of the frame rail exceeds
4 inches.
dmill89 is offline
post #3 of 15 Old 06-05-2013, 09:01 PM Thread Starter
TonyPgh
Originally Posted by dmill89 View Post
That looks like thin metal held on with sheet metal screws, not good. The proper way to repair this would be either with thick plates welded on or better yet cut out and replace the bad section (weld in a "new" rail section). I'd probable pull the screws and see what's underneath.
i have to drive my daughter to school tomorrow. I am afraid to put her in it.
I will tear it apart tomorrow. I am sick! I can't believe someone put fresh inspection stickers on it.
TonyPgh is offline
post #4 of 15 Old 06-05-2013, 11:44 PM
cdn_xj
I've returned to the fold
cdn_xj's Avatar
Not to be an ***, but did you not inspect it yourself before buying it?
'99 XJ Sport 4-dr
4.0 HO - AW4 - NP231 - D30, 4.10, Open - ChrysCo 8.25 29-Spline, 4.10, OEM Trac-Loc
Stock with a crapload of bolted on bits
cdn_xj is offline
post #5 of 15 Old 06-06-2013, 09:16 AM Thread Starter
TonyPgh
Yes I honestly did. He had it hidden with some filler and paint. It looked good!
I chipped it away, and found the surprise.
TonyPgh is offline
post #6 of 15 Old 06-06-2013, 04:10 PM
dmill89
1995 XJ Cherokee
That definitely explains why it passed inspection. Like I said above there is enough leeway in the regulations that a shop may have passed this, though a "good" shop likely wouldn't. But if it was hidden well enough the shop didn't notice it was repaired, it could have been "repaired" with cardboard and duct-tape and still passed inspection.
dmill89 is offline
post #7 of 15 Old 06-06-2013, 07:48 PM
cbenez1
Believe it or not this is fairly common on later XJ's. I just sold my 99 which had the same problem. The difference was I told the guy about it before he paid me? Not sure why the rail rots on these. Yours is a little lower than mine was. My problem was more over the axle. Don't panic it's not going to collapse on you. Chances are it won't be an issue but being near the spring mount you may want to take it to a trusted mechanic and have it patched/welded the correct way.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #8 of 15 Old 06-07-2013, 01:19 AM
Mike934
Happy to be in the scrotching deset of California, 104 today, no salt on the roads ever! Currently a cool 92 degrees with 23% humidity
honestly pull it apart check it out. If it ain't to bad I would look into HD offroad frame stiffeners. And then make some more "plates" to stiffen up/fix your issue. 1/8 is plenty fine. I opted for his middle stiffeners and made my own front & rear. Luckily we have a plasma. Ill never ever do my own again to much work, hassle, fitment ect. I would buy my whole set next go around and then add to them or around them.
I plated front & rear on the outside of the ral as well as bottom to help stiffen things and help rot or bending ect.
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #9 of 15 Old 06-07-2013, 05:52 AM
cdn_xj
cdn_xj's Avatar
Oh that sucks dude.,
'99 XJ Sport 4-dr
cdn_xj is offline
post #10 of 15 Old 06-07-2013, 08:16 AM
DNFJ
Given that it's rotting upwards towards the front leaf perch, I don't see how any shop could have missed that.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #11 of 15 Old 06-08-2013, 09:52 AM Thread Starter
TonyPgh
Thanks guys. I did see the off road stiffeners. They appear to be only the uni frame rails? Unless I am not realizing how far back and front they go. I seen them somewhere, can't remember now.
My drivers side is fine. Like new! Kind of odd.
The passenger side is crappy. The rear leaf area is fine.
The front where the leaf connects, I don't see that stud coming down like the drives side. Theres a bunch of crap shoved in it like putty or something. So I am sure I am going to have to repair where the leaf connects towards the front too. Maybe weld in a new brace.
I do like this Jeep. Although I have some work to do. It has a lot of power. The only thing I noticed is when you put it in 4WD, you have to slam it "the handle", hard back into 2wd, or it won't work.
I may pull the carpet and do the floor pans, and do it all the right way. I really like this Jeep! I see they sale a lot of stuff for them. I hope this don't end up to be an addiction...LOL
TonyPgh is offline
post #12 of 15 Old 06-08-2013, 10:06 AM
DNFJ
If you want any help, I'm willing to for a case of beer, given that I live so close. Plus if you're going to be welding I could use the experience (since I haven't bought my welder yet )
http://hdoffroadengineering.myshopif...ame-stiffeners
Previous:
DNFJ is offline
post #13 of 15 Old 06-08-2013, 10:58 AM
Mike934
Add to those plates in the rear. I added a 18" or so long section on the bottom of the rail where it bends up ward. I braced that, as well as a 12-14" section on the inside. I used 1/8th.
You can get flat stock that's 2.5" wide to ate it easy. Drill or plasma some holes for plug welding and form em to the rail with c clamps. & a few hammers. I did it so well back there because any flex, even changing a tire, would cause the hatch to not shut right, make it not close at all really because the body twisting. Same for the front doors, they have rub marks where they shut, paint rubbed off from shutting them while flexing. I enjoy it much better now, ride seem to have gotten stiffener/more controlled I guess. No more creaks & groans from the rear. and now I can flex it like mad and shut every door & the hatch without issue!
Personally I would buy brains(hd offroad) whole kit..for 300 bucks its well worth the investment. I added to his rears, and the fronts as well. Welded 1/8 on the lower front frame horn & on inside the engine bay to help brace it up since my motor was out. D what you can before you wheel it and beat it, I found zero cracks in my frame & hope it stays that way.
On ya and con someone into helping you grind all that **** away from the frame rails. It sucked majorly. Had a nice chuck of melted rubber/undercoating land on my arm. I then got smart and wore pants & a sweat shirt in 100* heat to finish the job
Mike934 is offline
post #14 of 15 Old 06-08-2013, 11:53 AM Thread Starter
TonyPgh
Thanks for the offer. I appreciate that. I am going to have to get materials. I always keep Bottled Beer on hand, ice cold, then of course lots of swearing while I am working. I guess thats normal...LOL
Thanks for the tips. I want to do it right, so it will last a while. I know I got off to a bad start, but I really like this truck. Something about it.
I seen this kit, is this the one you meant?
http://hdoffroadengineering.myshopif...-stiffener-set
TonyPgh is offline
post #15 of 15 Old 06-09-2013, 04:51 PM
Mike934
Yup. I didn't do his full kit, but after making my own front & rear plates I can tell ya, never again! And we have a plasma. They aren't as pretty, nor are they uniform like his, overall my set will work & do its just, his are just nicer, fit better ect ect.
Anyway add to those! Once those are on get some 2-3" wide 1/8" flat stock. Make fish plates, those will connect where your stiffeners but up together. And make plates to go on the bottom side of the rail. As you can see the middles do the outside & inside which is 2 plains, the fornt & rear only do the outside. So I made my own for the bottoms in the front and rear. As well as in the inside. F the engine bay since my motors out. It was plated where the engine bolts to the frame and such.
Here's a fish plate. Ou can see there's a plug weld on the front stiffener, 1 on the middles stiffener and between them on the actually frame rail. That small area will become a weak point that will start to bend or crack. The fish plate helps prevent it. Again I did mine on the side and bottom of the rail to help as much as possible. It's a labor of love but your jeep will feel stiff and brand new. I love mine after plating it all, no more creaks and groans.
Mike934 is offline
