Rear end vibration..help please! - JeepForum.com
post #1 of 21 Old 03-22-2013, 04:11 PM Thread Starter
bhansen99xj
So this has been a rough couple of weeks. I broke a leaf spring and ripped of my exhaust. A friend and I replaced the AAL + blocks 3" lift with some 3" rough country leaf packs. I took the XJ to a shop to have a new cat and muffler installed. Now, after everything has been repaired, I get some wicked vibrations at 55 - 70 mph. At 70 mph the vibes dull to a hum. It sounds and feels like it is coming from the rear as I don't feel it strongly in the steering wheel.
Anyone know what the problem could be? Engines are my thing. Suspensions, trannies, beatings..not so much. I searched a little but didn't come up with much in the way of definitive solutions. Also browsing mobile so please excuse not doing a thorough search.
Thanks for any help!
Cheers!
bhansen99xj is offline
post #2 of 21 Old 03-22-2013, 05:04 PM
cbenez1
You changed the driveline angle by lifting the rear. I'm guessing you did not do a t-case drop or use angle shims to raise your pinion angle ? Either one of these would help. The more expensive and sure way would be a slip yoke eliminator. Use the search for any of these 3 and you'll get all the info you need.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #3 of 21 Old 03-22-2013, 05:14 PM Thread Starter
bhansen99xj
The old lift was 3" and this problem didn't exist then. This is why I'm confused. Take out a 3" budget block/AAL and replace with 3" leaf packs. Thinking nothing should have changed.
The vibes really started when I snapped one of the original springs. Passenger side. I thought the vibes were related to the uneven angles I was traveling at.
post #4 of 21 Old 03-22-2013, 08:46 PM
cbenez1
Didn't realize it was lifted prior. However the lift blocks may have been taperd like a shim. Or you've got something wrong in the diff. Is it the same height with the new springs or did it change at all ?
cbenez1 is offline
post #5 of 21 Old 03-23-2013, 02:51 AM
VTEK1
Is it possible that the "3 inches" of lift could have shagged and the new "3 inches of lift" is actually higher giving you just enough more lift to cause the vibes. My 3 inch lift actually helped my vibes but my XJ's leafs were inverted the day I bought it 5 years ago. Just my 2 cents.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #6 of 21 Old 03-23-2013, 02:56 AM
91AzXJ
Try the simple things first and balance your rear tires. Also jack up the rear and put it on stands, then have someone slowly run it and watch to see if your drive shaft might be out of balance.
91AzXJ is offline
post #7 of 21 Old 03-23-2013, 04:10 PM Thread Starter
bhansen99xj
The block appears to have a slight taper to it. Does anyone know what the tolerable angles for the tc-driveshaft-differential should be? Really want to verify before I assume I need to drop the tc or go SYE. I don't want to put those efforts into it and find I need to change my axle bearings ot have to rebuild the differential.
post #8 of 21 Old 03-23-2013, 04:12 PM Thread Starter
bhansen99xj
I forgot to mention that I did rotate and balance all 4 tires and still have the same vibes starting at 55 mph.
post #9 of 21 Old 03-23-2013, 05:15 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Put some 4* shims to the leaf springs and go from there. Personally, I don't care for t-case drops but I've got a 1" spacer drop kit layin in the tool box I'd sell for cheap.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #10 of 21 Old 03-23-2013, 05:29 PM
cbenez1
I agree with Jeepn4kc. 4 degree should do it.
cbenez1 is offline
post #11 of 21 Old 03-23-2013, 06:17 PM Thread Starter
bhansen99xj
Is that something that would involve removing the springs all the way? Just looking at degree of difficulty and how much time I have to dedicate (how much time I can get out of spending time with my outlaws lol)
post #12 of 21 Old 03-23-2013, 07:17 PM
JeepN4KC
JeepN4KC's Avatar
Jack the Jeep up and put stands under the unirails.
Wheels off.
Let the axle drop and set on another set of stands.
Unbolt the u-bolts.
Unbolt the center-pin of the leafs (some guys use c-clamps to hold the packs together)
Bolt the shim to the bottom of the packs with the center-pin.
Torque the u-bolts back down.
yada yada - pretty much a cliffnotes run through but you don't have to remove the leafs to install shims.
~Mike~
WK
XJ
post #13 of 21 Old 03-24-2013, 04:30 AM
sAe23
1995 XJ Cherokee
If you don't have a SYE, the pinion and T-case output need to be parallel.
Get a cheap angle finder and MEASURE your setup before installing shims...
sAe23 is offline
post #14 of 21 Old 03-24-2013, 06:42 AM
JeepN4KC
JeepN4KC's Avatar
Good point. Hell I'm not an "app" savvy dude but I have an angle finder/level app on my phone.
~Mike~
WK
XJ
post #15 of 21 Old 03-24-2013, 10:25 AM
cbenez1
In a perfect world maybe but thats a little overkill in most cases. Neither of my Xj's are parallel and both have no vibes. I would go with lessening the angle until the noise/vibration goes away.
cbenez1 is offline
