Quantcast Rear end clunk...2001 XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rear end clunk...2001 XJ
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-28-2007, 09:04 PM   #1
chicagoshooter
I am experiencing an "occasional" clunk in the rear end of my Jeep right after stopping or just starting to accelerate. There are no other sounds while driving. When I make a slow gradual stop this does not appear. When I make a normal or slightly aggressive brake it sometimes appears.
I was told my u-joints are in good shape. My left rear leaf spring is sagging just a little lower than the right, I am about to replace those soon.
I have also heard in some Jeeps about the rear drums shifting on the hubs, but not sure if this applies to my 2001.
Any ideas?
Thanks,
Mike
chicagoshooter is offline   Reply With Quote
Old 12-28-2007, 09:06 PM   #2
bmyohn
Youngin'
bmyohn's Avatar
how are your bushings in the leaf springs, shackles, and shocks?
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 12-28-2007, 09:11 PM   #3
srmitchell
My car has a know problem of worn shocks in the rear, I get a bad clunk over every bump, i'd check that.
Im sure its my upper shock bushings.
Good luck.
I have an xj and it is blue
srmitchell is offline   Reply With Quote
Old 12-28-2007, 09:15 PM   #4
chicagoshooter
have not checked...
I am going to put in new bushings in the leaf springs when I replace them. I can check the shackles too, I did not know they had bushings. I am new to Jeeps
Old 12-28-2007, 09:19 PM   #5
JeepRide
got a 98 xj it does the same thing
98 xj 4.0L 231 t\case off road commode
4 in the floor and a fifth under the seat
Eat more possum
JeepRide is offline   Reply With Quote
Old 12-28-2007, 09:27 PM   #6
itasor
2009 JK Wrangler
You need to take your rear drive shaft off and lubricate the slip joint on the transfer case end. On pre 96 XJ's it's lube by the transfer case fluid, but on newer XJ's it isn't lubed by anything and wears out over time causing a clunk sound exactly as you described.
itasor is offline   Reply With Quote
Old 12-29-2007, 11:23 AM   #7
Rowingfish87
I have a "clunk" coming from my rear-end as well. mine is more of a "click click click click click" as I'm braking going from around 20-10mph then it goes away. sounds like its coming from the left rear. I took the drum off to see if the pads were loose or too worn...both fine. my axle does slide in and out of the housing about 1/16-1/32 of an inch...is that normal?
any other ideas?
Rowingfish87 is offline   Reply With Quote
Old 12-29-2007, 11:42 AM   #8
itasor
2009 JK Wrangler
any other ideas?
I had a click click click sound when I was braking and it ended up being a busted spring inside one of the drums. If it only happens when you brake, it's probably not the axle.
Old 12-29-2007, 12:40 PM   #9
vswv8
there's a tsb for clunking in the rear of the later cherokee's...........could be problem, IF everything else is propper.......
99 cherokee sport
5" lift with 32x11.50x15 cooper xtx at's
(NO RUBBING/TRIMING!!!!)
unknown free rims with 4" backspace
factory/drawtite hitch outback
48 cj2a willys 231 oddfire v-6
2.5-1 transfer w/t150 trans
custom rollcage-ramsey 8000lb winch
custom built(by me!)body armour
custom built(u geussed it!) nerf bars
firebird tilt steering w/gm 1/2 ton truck power steering out front fabbed in by me
4" lift
currently 31x10.50 15s.....set up for 35's
vswv8 is offline   Reply With Quote
Old 12-29-2007, 12:45 PM   #10
davevolk
I have the exact same problem with my 2001 XJ Sport. If you are real gentle with making a stop I don't get any "clunking" noise, but if I make a normal or sudden stop I get a definite rearend clunk. I did grease my the rear drive shaft zerk fitting slip shaft at the transfer case this fall. I have checked everything at it all seems tight. I don't recall hearing this noise before a few months back.
Dave
2001 XJ Sport
125,000k
davevolk is offline   Reply With Quote
Old 12-29-2007, 12:56 PM   #11
itasor
2009 JK Wrangler
Dave
2001 XJ Sport
125,000k
There is no zerk fitting on the rear driveshaft. The front one has a zerk on the slip joint, so maybe you're getting them confused.
Old 12-29-2007, 01:16 PM   #12
cajunbull61
My 2001 has a light clunking noise when slowing down. I have put discs on the rear and had a complete rebuild of the rear end and still have the noise. I'm thinking the bearing surface on one of the axle shafts may be worn.
cajunbull61 is offline   Reply With Quote
Old 12-29-2007, 02:16 PM   #13
chicagoshooter
hmmm...
It sounds like this is common. I just do not want it to be a major issue and need even more repair at a later time. I will probably learn more when I replace the leaf springs and the drum brake hardware.
Thanks
Old 12-29-2007, 02:36 PM   #14
itasor
2009 JK Wrangler
Thanks
Like I said I would lube the slip joint before digging into the brakes or anything else. It's known that an unlubed slip joint causes clunks just like you're talking about.
Old 12-29-2007, 03:03 PM   #15
sublime600
Mine did same exact thing, I did this and now cured. Only takes less than an hour. http://www.jeepforum.com/forum/f11/greasing-slip-joint-97-xjs-write-up-357569/
sublime600 is offline   Reply With Quote
Glock Forum
