rear driveshaft - JeepForum.com
post #1 of 4 Old 08-15-2013, 06:40 AM Thread Starter
mollydodger
2009 FSJ Cherokee
rear driveshaft
My drive shaft is badly rusted. Not just the average surface rust but really heavy and nasty scaling type rust. I think there may have been a balancing weight that is now gone and causing some minor vibes at certain speeds. I have searched a local salvage yard for a replacement but they tell me there are different shafts depending on drive line manufacturers. Is this true and how can I tell which one I need to get? Thanks in advance.
mollydodger is offline
post #2 of 4 Old 08-15-2013, 03:03 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
As long as you get close to the right year you will be fine,I have a front d/s from a 01 on the rear of my 98 and it works up front also.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #3 of 4 Old 08-15-2013, 03:46 PM
Holder350
1995 XJ Cherokee
Should be added that a SYE is needed to run a front shaft in the rear.
But the only thing you need to watch out for is to make sure the new shaft comes from a jeep with the same transmission as yours. Auto and manual have different length shafts.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 4 Old 08-15-2013, 05:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by mollydodger View Post
.. Is this true and how can I tell which one I need to get?
Yes, this is true.
1) What engine do you have 6 cylinder or 4 cylinder ?
2) Stick shift or automatic transmission ?
3) The only remaining question is which of 2 possible rear axles. Use the Google and search for how to tell the difference between the two.
When you know the answer to these three questions, buy a drive shaft from a 1997-2001 with the same engine/transmission/rear axle.
CJ7-Tim is offline
