Rear drives haft U joint too small - JeepForum.com
post #1 of 7 Old 06-02-2012, 06:35 PM Thread Starter
spectre853
I am trying to replace my rear drive shaft U joint at the axle. I stopped by Autozone and grabbed what I thought I needed, only to discover that it was about 1/2" too narrow for both the drive shaft and the pinion yoke. After then going to O'Reilly and having them sell me another too small U joint, I've measured and discovered it to be a 3.625" x 1.0625" joint, equivalent to the Dana Spicer 1330. However, it has the outside lockup spring clips (as opposed to the inside lockup c-clips). Any idea what the off-the-shelf equivalent to this joint might be, and why I'm having such difficulty finding it?
spectre853 is offline
post #2 of 7 Old 06-02-2012, 06:51 PM
lsmurphy
It's supposed to have the outside clips.
lsmurphy is offline
post #3 of 7 Old 06-03-2012, 06:29 AM
unkajeffy
I had this problem yesterday,with front axle u-joints. Got on here and was reminded the some yj parts fit in the cherokee. And had em look up yj axles and bingo had a u-joint.
Michigan Yankee in Redneck Land
unkajeffy is offline
post #4 of 7 Old 06-03-2012, 07:16 AM
lsmurphy
There is a change in the axle shaft u-joints.........smaller to larger.......don't remember the change year though.
To the PO..........stock or not?
Take the old one and have them match it up.
lsmurphy is offline
post #5 of 7 Old 06-03-2012, 07:21 AM Thread Starter
spectre853
After some digging, I found that Neapco P/N 2-4800 U joints are the same thing as the Dana Spicer 1330 U joints, and they carry them at Pep Boys for about US$10.
post #6 of 7 Old 06-03-2012, 07:27 AM Thread Starter
spectre853
Here's the resources I used:
Table for identifying Dana Spicer outside lockup U joints: http://www.driveshaftspecialist.com/..._LOCK_U-JOINTS
Table with OEM part numbers and suitable substitutes: http://www.drive-lines.com/ujs/bpujs.php
post #7 of 7 Old 06-03-2012, 08:17 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
All XJ Cherokee were built with Spicer 1310 u-joints in the drive shafts.
If you need a 1330, somebody made a change at somepiont to your Cherokee.
CJ7-Tim is offline
drive shaft , u joint
hack n tap sye HELP ME. rear u joint too small? kyleyz762 XJ Cherokee Technical Forum 5 05-08-2011 10:09 PM
Rear U-Joint JeepXJ2857 XJ Cherokee Technical Forum 14 12-22-2010 03:41 AM
small vib from rear end and leaking diff fluid whiteys_red_XJ XJ Cherokee Technical Forum 2 07-31-2010 08:36 PM
Will a small sub fit under rear seat? tizzdizz XJ Cherokee Technical Forum 17 01-08-2008 07:38 PM
How to remove rear small window on drivers side twisted_ed XJ Cherokee Technical Forum 1 03-24-2005 10:42 AM
