Rear drivers side passenger door won't unlock... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Rear drivers side passenger door won't unlock...
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-01-2013, 05:32 PM   #1
DerMeister
Any idea on how to fix it? Never been inside a door on any vehicle.
It will lock, but not unlock unless I do it manually.
DerMeister is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 06:44 PM   #2
Paradise XJ
1988 MJ Comanche
Power lock or manual lock
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 07:19 PM   #3
DerMeister
Power locks.
Unread 07-01-2013, 07:22 PM   #4
jonsnw93
Try spraying WD-40 inside the latch of the door. I did that on all of mine and they work a lot better now
jonsnw93 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 11:52 PM   #5
DerMeister
I gave that a go, after cleaning them out with brake cleaner. No dice.
Unread 07-02-2013, 07:35 AM   #6
M35A2
1995 XJ Cherokee
You'll probably need to pull the panel off and check voltage at the plug. It could have a broken wire. They tend to break where the harness passes thruogh the door jamb from the body to door. I have a wire issue for the ft pas. window, it will roll up, not down unless I push up on the harness.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 01:09 AM   #7
mas76
1992 XJ Cherokee
possibly the power lock actuator
my 92 started slowly on one door, would lock but not unlock, then it spread to the other doors, it started out worse in the cold, then would work when they warmed up
guy at the dealership suggested taking the door panels off, cleaning them out and lubricating them, i still havent gotten to it yet, but new power lock actuators were close to $200 each through the dealer, not sure if there is an aftermarket actuator available, i've just lived without the convenience of the power locks, it hasn't bothered me enough to be a priority and i haven't had the free time to spare to mess with it
mas76 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 12:44 AM   #8
jonnys303
You may want to check your ground wires too, if you don't have a good ground it can make the solenoid act weird.
jonnys303 is offline   Reply With Quote Quick reply to this message
