Rear driver door stuck on lock - JeepForum.com
post #1 of 6 Old 02-22-2011, 03:27 PM Thread Starter
reindeerfuel
97 Cherokee
Manual locks
Rear Drivers Side Door
Ive got the panel off from the inside and tried pushing and pulling the rod to unlock it but having no luck. I soaked everything i could see in there with WD40 with still no luck. Anyone know how to get it unlocked?
reindeerfuel is offline
post #2 of 6 Old 02-22-2011, 03:32 PM
Bock
Not to thread jack. My 96 with power locks won't open from inside or outside
96 XJ Country White AW4 4*4
If it breaks it just means upgrade
Bock is offline
post #3 of 6 Old 02-22-2011, 05:29 PM
AZ Jeff
2014 JK Wrangler
Look in with a flashlight an observe where the push/pull rod connects to the door latch assembly. See what is keeping it from pivoting.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 6 Old 03-11-2011, 07:15 PM Thread Starter
reindeerfuel
**UPDATE**
I got the door open and found the problem, it was not stuck on lock but the rod that is supposed to go back up after you pull/push the lever on the handle to open the door does not go back, the spring and components are rusted. I soaked in WD40 and moved it up and down by hand but it is still not retracting like it should. Anyone know how to fix this or am i just going to have to replace it?
here is a pic of what im talking about
post #5 of 6 Old 03-11-2011, 07:32 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
WD-40 is neither a cleaner nor lubricant. Use Throttle Body cleaner spray to remove any old grease on the door latch and door handle/Lock mechanisms. Use a light oil to lubricate everything. Break Free CLP gun oil is a Cleaner Lubricant Product and works great for door lock/latches.
If the whole mess is too rusty, stop by the junkyard and get a replacement.
CJ7-Tim is offline
post #6 of 6 Old 03-12-2011, 02:29 PM Thread Starter
reindeerfuel
Thanks tim, found a can of carb cleaner in the garage and sprayed it out with that. After moving it with my hand a few times it would retract on its own and now my door is fix! thanks a bunch for your advice.
Driver Door Lock viper719 XJ Cherokee Technical Forum 7 01-26-2009 06:23 PM
Driver Door stuck??? 89mudlite XJ Cherokee Technical Forum 13 12-27-2007 10:45 PM
Driver door stuck closed ar275103 XJ Cherokee Technical Forum 1 06-20-2007 01:29 PM
Driver Door won't Lock awightaz XJ Cherokee Technical Forum 3 03-20-2006 08:55 AM
driver side door lock picabo street XJ Cherokee Technical Forum 7 05-14-2003 08:12 AM
