rear diff grinding noise - JeepForum.com
post #1 of 8 Old 10-21-2013, 07:04 PM Thread Starter
harcoredneck
hey fella's i've been having some problems with my rear diff now. every now and then while im at either a stop sign or red light and i punch the gas i hear some grinding noise and when i had it on jack stands and put the transmission and t case in neutral and i rotate the drive shaft and felt some play in it and when i rotate it for like half to 3/4 rotation it wont spin the tires. anyone know whats wrong with my rear diff?
harcoredneck is offline
post #2 of 8 Old 10-21-2013, 07:21 PM
ashland82391
Sounds like you missing teeth on your pinion/ring gear. Time for a rebuild or upgrade...
ashland82391 is offline
post #3 of 8 Old 10-22-2013, 11:27 PM Thread Starter
harcoredneck
i got an extra rear axle on my deck just incase
post #4 of 8 Old 10-23-2013, 02:40 AM
xj2k1
Just be sure it's the same gear ratio.
xj2k1 is offline
post #5 of 8 Old 10-23-2013, 09:17 AM
egodfrey
egodfrey's Avatar
Only way to truly know whats going on there is to take off the diff cover and look.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #6 of 8 Old 10-23-2013, 10:58 PM Thread Starter
harcoredneck
the next time i have 2 days off in a row, i'll do that
post #7 of 8 Old 10-24-2013, 08:17 AM
AZ Jeff
2014 JK Wrangler
You shouldn't need more than 2 hours to do the inspection.
Now depending on what is wrong inside, 2 days might be a good estimate for repair time.......
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #8 of 8 Old 10-27-2013, 09:38 PM Thread Starter
harcoredneck
just checked my schedule and i am going to buy a thing of differential oil and when it comes to those two days i have off i'll work on fixing it
