rear diff - JeepForum.com
post #1 of 7 Old 08-09-2015, 10:29 AM Thread Starter
2001XJMuddin
rear diff
does anyone know for sure what a 2001 cherokee sport has rear differential wise? I have no tags on it at all. has no trailer towing package either. Needs new bearings and Im changing the fluid out as well.
2001XJMuddin is offline
post #2 of 7 Old 08-09-2015, 10:32 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Only you know for sure, until you post pictures, or read this thread -> 8.25 or Dana 35 ?
CJ7-Tim is offline
post #3 of 7 Old 08-10-2015, 02:00 PM
bluejunior
Hold my beer
bluejunior's Avatar
You're a 4.0 auto, so you'll have 3.55 gears unless it has the factory tow package, in which case it'll be be 3.73's. As far as WHICH diff you have, follow Tim's link and let us know.
Lifted, Locked, Stiffened
Build
bluejunior is offline
post #4 of 7 Old 08-10-2015, 03:57 PM
CJ7-Tim
CJ7-Tim's Avatar
The AMC 3.73 gear tow package was discontinued shorty after Chrysler bought Jeep.
CJ7-Tim is offline
post #5 of 7 Old 08-10-2015, 04:07 PM
bluejunior
Hold my beer
bluejunior's Avatar
Crap...2001 is in the name and everything. 3.55 for sure then.
Build
post #6 of 7 Old 08-10-2015, 04:18 PM
rugsucka
Do you have ABS? Is the axle tube 2 & 3/4"?
-I'm sorry to say that you have a D35. Try not to lock it and run tires bigger than 32"
Does your diff have a distinctly flat bottom lip and a couple little horns on the top of the pinion section? (where the driveshaft bolts to the yoke) Is the axle tube 3"?
-Congratulations! You have a 8.25 w. 29 Spline axle shafts. You have a very stout axle that will handle 35's locked and abused to a point.
rugsucka is offline
post #7 of 7 Old 08-11-2015, 08:04 AM
RLE
RLE's Avatar
According to the Parts Catalog:
For 2001, the 8.25 only had 3.07 and 3.55 gears.
The Dana 35 had 3.07, 3.55 and 3.73 available.
When you change out the fluid, you can look at the numbers
stamped on the ring gear and you'll know for sure what diff
and what gear ratio you have.
RLE is offline
