Rear courtesy light lens removal -how - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rear courtesy light lens removal -how
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 12-31-2009, 08:14 AM   #1
greenlawnjeeper
I guess this is technical .
That courtesy light, the one on the inside (top) when you raise the rear gate. htf do you get it off? The "pusher" on-off switch is stuck on mine. Do I just pry it off with a screwdriver or somethin' . Figured I'd ask before I try and end up busting it. Thanks.
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline   Reply With Quote
Unread 12-31-2009, 08:20 AM   #2
oderalxjlaredo
On mine, I just squeezed the sides of the lens and it came off easily
by the thing that spins when you drive underneath
oderalxjlaredo is offline   Reply With Quote
Unread 12-31-2009, 08:49 AM   #3
greenlawnjeeper
OK then, I will try that. Thanks,
