Rear coil conversion - JeepForum.com
post #1 of 8 Old 11-22-2005, 08:50 PM Thread Starter
WhiteKee
Hi !
I will convert my Xj to coils in the back. It's only for 35x10.5 Swamper SSR
Wich setup is the good one, in this list.
3 link
4 link
Or your idea ?
Thanks
FS-TJ
4.0l/aw4/teralow
Dana 44/AMC 20 4.5 SPOOL
8'' LIft Long arm
Rear double Triangulated 4 link100'' Wheelbase
37'' Irok
WhiteKee is offline
post #2 of 8 Old 11-22-2005, 11:12 PM
JeepinJerimiah
JeepinJerimiah's Avatar
There is already an active post on this same topic about 21 threads up.
http://www.jeepforum.com/forum/showthread.php?t=211863
Click on and post away !
-JeepinJerimiah-
1994 Cherokee SE/ChyCo 8.25/4.0 HO/AW4/Custom Drive Shaft/Rusty's 3" Full Pack /Cragar Soft 8's 15x8/Dakota M/T 31x10.50x15/Custom Cat Back/Walmart Lights/Bedlined Rockers/Alpine CDA-9843 Head/160xxx Miles
JeepinJerimiah is offline
post #3 of 8 Old 11-22-2005, 11:59 PM
Rock Kustoms
Rock Kustoms's Avatar
you guys are professionals at screwing links up
http://www.jeepforum.com/forum/f11/8-lift-rear-coil-over-conversion-211863/
Rock Kustoms is offline
post #4 of 8 Old 11-23-2005, 12:38 AM
JeepinJerimiah
And you are a professional at fixing them up
thanks man
-JeepinJerimiah-
post #5 of 8 Old 11-23-2005, 09:34 AM
Rock Kustoms
never a prob, as far as rear coils, theres a huge difference than rear coilovers
the susension links are the same, but everything else is different, coils take up a hell of a lot more room, and you need room for a shock
IMO, you NEED to notch the unirail, for the spring seat, using as long of a spring as possible
i reall dont know if i like the idea of rear coils on an xj, ive seen a lot of them, and they have tons of flex, but the springs unseat way toooooo soon, so if you were to set up a limiting strap in the correct location, i dont think youd flex much more than a cherokee w/ a good leaf pack
post #6 of 8 Old 11-23-2005, 10:04 AM
fryed_1
The ride handling is much better IMO though... and a bit easier to tune and modify than pulling apart a leaf pack, granted you get your CA setup right the first time.
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline
post #7 of 8 Old 11-23-2005, 10:51 AM
matt6669
theres some good useful information posted in that thread above
are you planning on building your own kit or you planning on buying a kit from someone.
Matt
matt6669 is offline
post #8 of 8 Old 11-23-2005, 04:47 PM
Rock Kustoms
itll ride on the street better, but, i like leafs in the rear, kinda a sway bar, but i do want the adjustibility, so im going to to 1/4 elips
Coil sprung conversion for the rear? ProMod1385 XJ/MJ Cherokee Non-Technical Forum 10 07-15-2008 07:47 AM
Rear coil conversion?... Bryson XJ Cherokee Technical Forum 11 12-30-2007 12:31 PM
ZJ/WJ Rear Coil Spring Conversion StokedXJ11 XJ Cherokee Technical Forum 4 01-07-2007 12:57 PM
Clayton rear coil conversion... Joe S. XJ Cherokee Technical Forum 9 10-21-2005 07:28 PM
Coil Over Rear Suspension Conversion ATX XJ XJ Cherokee Technical Forum 9 04-20-2005 09:51 PM
