#1 | |
Rear brakes dragging?
I swapped in a boneyard '98 8.25 w/4:10s yesterday, getting rid of my Dana 35. I had the drums turned and replaced the shoes. I adjusted the brakes like I always do, with just a slight bit of drag. I pulled out and heard them dragging a good bit. I thought I had them too tight, so I pulled back in and loosened them to a "no-drag" state. After doing the auto-adjust thing, they're dragging slightly again. I checked the e-brake cables and it's not tight at all. It sounds like a sort of scraping noise. The springs are on correctly. The only thing I can think of is the wheel cylinders. The axle was sitting for quite a while before being sold.
Ideas?? TIA! ![]()
'05 LJ Sport, 6-speed, SwayLoc, LoD bumpers...the build begins! '11 JK Unlimited Sport S, stock for now... |
#2 |
I had the same problem new wheel cylinders and brake proportioning valve later problem solved.Mine was actually
skidding on right rear wheel and mostly when it was wet out.Hope this helps you.
addicted to trails freedom and jeep 1991 xj limited 4.0l ho full load 1989 xj 5inch lift 32x11.5x15 mudders on eagle mods 1995 jeep yj (project bogger) |
#3 |
I swapped out the wheel cylinders, and have the same symptom. I'm really lost now.
I also used the e-brake cables from my Dana 35. THAT wouldn't have any effect, would it? It seems fine until I've driven it enough to adjust the brakes. Then the scraping sound starts. Here's another twist... I got home and the brakes were scraping, but the drums pulled off EASY! ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
