rear brake vibration - JeepForum.com
post #1 of 8 Old 05-03-2009, 05:34 AM Thread Starter
artboy
artboy's Avatar
I have a bad vibration coming from the rear brakes when I brake over 40. It also happens when I pull on parking brake slightly at speed. IT IS DEFINATELY THE REAR BRAKES!! I REPLACE THE SHOES AND DRUMS.. still there. Only thing I can find is when I turn the passenger wheel to adjust star wheel the shoes grab unevenly as the wheel turns as if the drum were warped (but it is new)! did the same thing with the last set of drums I had as well. Could the axle be slightly bent?.. only thing I can think of.. HELP! PS.. there are no vibes at all unless braking
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231
1996 XJ Sport Daily Driver - 190k, stone white, 4.0, automatic, selec-trac NP242.
2005 Wrangler Rubicon Summer Toy - 26k, 100% STOCK...silver, automatic, soft and hard tops and doors
"life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller
artboy is offline
post #2 of 8 Old 05-03-2009, 06:06 AM
jd4x426
check and make sure you brake pads are setting in properly make sure the springs and cables in there are all working properly also
jd4x426 is offline
post #3 of 8 Old 05-03-2009, 08:08 AM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
switch over to rear disc breaks you will love em,I just did mine got them of a grand cherokee but I have heard you can bolt up liberty rear discs with no problems so might be worth looking in to.i would also check and see if the axle is stright just jack up the back and spin the tire to see if it wobbles or not.be sure to check your rims also
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #4 of 8 Old 05-17-2009, 09:23 PM
Fox Fader
I've been fighting the same problem now. I can't figure it out. Here's my thread
http://www.jeepforum.com/forum/f11/slight-vibration-braking-before-after-brake-service-751677/
God Rules!
Fox Fader is offline
post #5 of 8 Old 05-17-2009, 10:42 PM
waltercrovo
The Drums/or Drum Is Bent, Common Problem When A Shop Or Person Prys Or Beats Them Off With A Hammer. They Get Stuck Pretty Good. If Not To Bad Machining Them Will Cure It, If Not R/r Will Be The Cure.
waltercrovo is offline
post #6 of 8 Old 06-12-2009, 03:11 PM
EvansXJ
Vibration under braking 98 XJ
I have been having the same prob. Driving me crazy! I can hear and feel the vibe near shifters for tranny and transfer case while in the jeep. Only under braking. Also if you use e-brake only, just not as pronounced. I replaced drums and shoes today, w/ new wheel cylinders and hardware kit. Thought I had a warped drum. No deal. Also have replaced shocks, steering stabilizer,trans mount, motor mounts,swaybar bushings w/ links. New u-joints. I think you get the idea. I can't duplicate the sound while on a lift. Only on the road. Vibe is there in any gear on tranny, w/ or w/o 4WD, get up to speed in nuetral, still there. Also with tranny in nuetral and transfer case in nuetral. Also can slightly hear same sound while going down thw h-way over bumps that get the suspention kinda floating. PLEASE HELP
EvansXJ is offline
post #7 of 8 Old 09-13-2011, 08:41 PM
97babyxj
Bringing it back to life, any solutions for this problem? I am encountering a similiar issue with my 99.
99 XJ - A Fresh Start
97 XJ - Being 'fixed' (off the road for a while)
67 Chevelle Malibu - 327+th350 and some rust
97babyxj is offline
post #8 of 8 Old 09-14-2011, 06:03 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You could have a bent axle flange or drums out of round. Have the drums turned and check the axle flange by spinning a jacked up wheel to observe run-out.
cruiser54 is online now
Slight Vibration on Braking Before and After Brake Service Fox Fader XJ Cherokee Technical Forum 19 05-22-2009 05:35 PM
Brake Pedal Vibration louisd11 XJ Cherokee Technical Forum 3 05-02-2009 07:31 AM
00 Cherokee brake vibration racerzer0 XJ Cherokee Technical Forum 6 06-22-2006 01:12 PM
Brake Vibration mnovak16 XJ Cherokee Technical Forum 4 04-15-2006 02:42 AM
Brake pedal vibration Jeep Cherokee XJ Cherokee Technical Forum 9 02-27-2004 09:21 AM
