Rear brake shoe question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Rear brake shoe question
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitSavvy Billet LED Tail Lights
Unread 02-12-2011, 10:18 AM   #1
samger2
Sorry if this is a stupid question, but I'm not sure if I need to replace my rear brake shoes. I know rear brakes typically go a long time before needing replacement, so I popped the R/R drum off today. I'm not quite sure if these are worn to the point of needing replacement yet. I don't have a micrometer to measure the thickness...so I tried to just put a ruler against the thickness remaining on the shoe. But what is minimum thickness?
2000 XJ sport, I have just shy of 100k on it, and have owned it since it had 48k, so I'm not sure if these are the original shoes or not, I have to assume they are. Thanks in advance.
samger2 is offline   Reply With Quote
Unread 02-12-2011, 11:10 AM   #2
AZ Jeff
2014 JK Wrangler
The normal rule of thumb for riveted linings (which you have) is to replace them just before the lining is flush with the head of the rivet.
Inspect all the rivets, and look for the one closest to the top surface of the lining, and that is your guage.
AZ-Jeff
1992 XJ -- stock (RIP)
2000 XJ -- lots of basic mods. Sold to fellow forum member. I miss it.
2014 JK -- the project is just starting!
AZ Jeff is offline   Reply With Quote
Unread 02-12-2011, 07:35 PM   #3
samger2
Cool...thank you very much
