Rear brake line help - JeepForum.com
post #1 of 9 Old 04-16-2011, 07:03 PM Thread Starter
Rusty328
1993 XJ Cherokee
Hey just hoping someone can shine some light on my problem. I bought a new rear brake line and it is the axle breather and at tee for the two hard brake lines. Just wondering how I can can get the old one out and the new one in. Thanks for any help.
Rusty328 is offline
post #2 of 9 Old 04-16-2011, 07:18 PM
Wearingthin
The breather hose is actually a hollow bolt that holds that junction box to the axle. Unscrew the two brakelines from the junction box, then unscrew the breather hose, then you'll have to unscrew the brake line that runs into the softline at the frame end. You'll see a little plate that fits into that fitting attached to the frame. You have to pull that out to free the softline from the frame.
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #3 of 9 Old 04-16-2011, 09:57 PM
JeepRide
JeepRide's Avatar
A brake line wrench also called a flare wrench helps to loosen the steel lines without rounding off the fittings.Be prepared to have to install new brake lines if yours are rusted up pretty bad.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #4 of 9 Old 04-16-2011, 10:15 PM
Jonny7
1990 XJ Cherokee
I would use the rear brake line for a 95 yj since it is longer and you are lifted. I got mine at advance auto, part # H38845
Jonny7 is offline
post #5 of 9 Old 04-19-2011, 05:53 AM Thread Starter
Rusty328
1993 XJ Cherokee
thanks was driving me crazy
Rusty328 is offline
post #6 of 9 Old 05-19-2011, 06:18 AM
mntn-biker
NAPA Auto has the same part. 95 YJ P/N 38845. Napa Auto site shows the actual hose length on their site. The XJ brake hose length is 13.25" long and the 95 YJ hose length is 16 3/8" long.
mntn-biker is offline
post #7 of 9 Old 06-23-2013, 12:46 PM
Mattfox1025
Anybody know why the thread in the new hose is too big for the brake line thread?
Mattfox1025 is offline
post #8 of 9 Old 06-23-2013, 08:28 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
The 3" longer 95 YJ line works great on my 96 XJ and brought me the little more extra length I needed.
***Chris***
chris87xj is online now
post #9 of 9 Old 06-24-2013, 05:52 PM
rugsucka
You bought the wrong part?
It's a 3/16" brake-line & double flare fitting.
I also used a mid nineties Dakota in the rear for the flex line.
For the front ~4-5" you can use Chevy Silverado flex lines.
rugsucka is offline
Rear YJ Brake line for XJ billabongopblue XJ Cherokee Technical Forum 3 09-10-2009 11:34 AM
Brake line going to the rear jrskblx125 XJ Cherokee Technical Forum 8 11-23-2008 01:23 PM
Brake line replacement.....rear flex line Captainkirk XJ Cherokee Technical Forum 1 10-26-2008 12:43 AM
How to get rear brake line off? Timberwood XJ Cherokee Technical Forum 5 05-04-2008 05:52 PM
Rear brake line!!!! Muddy Cherokee XJ Cherokee Technical Forum 4 03-08-2006 12:07 AM
