Quantcast Rear axles how can I tell...- - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rear axles how can I tell...-
Old 06-12-2004, 05:02 PM   #1
JEEPIUS
if I had a Dana 35 or Chrysler 8 1/4"?
Which is better?
Scott
JEEPIUS is offline   Reply With Quote
Old 06-12-2004, 05:06 PM   #2
ChiTown'01XJ
Which is better?
Scott
You can look at the axle itself and it will be stamped with what it is, i just found out yesterday mine was the CD 8 1/4" as i was taking off the sway bar. ABS = D35, no ABS = CD 8.25"
[COLOR=blue]Blue Jeep Club Member #73[/COLOR]
'01 XJ Sport
235/75/15 BFG All Terrain T/A KO, C4X4 tow hooks, rear hitch, 2 x 55 Bosch Lights, Cobra 19+ (waiting on antenna)
[B]"Let's do it in the dirt"[/B]
ChiTown'01XJ is offline   Reply With Quote
Old 06-12-2004, 05:28 PM   #3
GottaBeJeep
Not always true. Some of the earlier XJ's had D35's without ABS. Best way to tell is just to look. Here is a picture to compare the two. The left is the 8.25 (notice the round cover and the housing is flat at the bottom) and the right is the D35 (oval cover and housing).
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Old 06-28-2004, 10:02 PM   #4
jaardesign
so wich rear axel is better, the D35 or the CH 8.25?
'92 4x4 4door Cherokee Limited with 100k
RE 4.5" lift with full leaf packs, adjustable LCAs (with SkidRow skidplates)and UCAs, adjustable track bar, JKS discos, front and rear steel breaded brake lines, DPG bump plates, front+rear hitch, and 31" bfg ATs
Colorado rocks!
jaardesign is offline   Reply With Quote
Old 06-28-2004, 10:06 PM   #5
GottaBeJeep
The 27 spline 8.25 is barely better, but still pretty weak. The 29 spline 8.25 is quite a bit stronger and is almost comparable to the Dana 44.
Old 06-28-2004, 10:08 PM   #6
jaardesign
how do i tell if its the 27 or the 29 spline?
Colorado rocks!
Old 06-28-2004, 11:00 PM   #7
wipedawg
If you have a 92 its a 27 spline.
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline   Reply With Quote
Old 08-08-2004, 10:19 AM   #8
Osteonis
2008 KK Liberty
What if you have a 99?
[FONT=Comic Sans MS][COLOR=DarkRed]99 XJ Sport[/COLOR][/FONT]
Stock
I6
5spd
Class III Hidden Hitch
235/75/15
Bumper Mounted Fogs
Osteonis is offline   Reply With Quote
Old 08-08-2004, 10:21 AM   #9
GottaBeJeep
29 spline if it is the 8.25.
Old 08-08-2004, 03:40 PM   #10
scotty'98
sorry to do this to ya'll but what if its a 98 sport? thanks,
Scotty
scotty'98 is offline   Reply With Quote
Old 08-08-2004, 03:43 PM   #11
GottaBeJeep
29 spline if 8.25. If it is an 8.25, 97 and newer XJ's had the 29 spline axle, and the later production 96's had the 29 spline. If you have a 96, you'll probably have to pull the shafts to find out if you have the 27 or 29 spline if you have the 8.25.
Old 08-08-2004, 07:47 PM   #12
Lucky13
i have a 93' sport i just went out and checked the rear i have a mopar 8 1/4 but what spline are my axles?
Me and my friends did acid in the woods, 'cuz there was much less chance of running into an authority fugure. But we ran into a bear. And that is way more of a buzz kill. I looked around and saw my friend swearing to prevent forest fires. Later, he came up to me and said, "Mitchell. Smokey is way more intense in person.- Mitch Hedberg
Lucky13 is offline   Reply With Quote
Old 08-08-2004, 09:30 PM   #13
DMacabre
you have the 27 spline
88 MJ: some assembly required
98 XJ 2dr: little lift, lotta skidplate
www.wnyoffroad.org
DMacabre is offline   Reply With Quote
Old 08-08-2004, 10:28 PM   #14
Lucky13
will a 29 spline 8 1/4 axle housing bolt right into my xj? or is it just better to buy i different axle like a Dana 44?
Old 10-27-2004, 08:52 PM   #15
madXJ
Interesting. I'm gonna seal the deal on the '96 Cherokee Sport tomorrow. I took one last look earlier this evening to try and figure out which axle it's equipped with. The housing is flat on the bottom, so I've got the Chrysler!
But this is the first time I've heard about the late 96's having the 29 spline. Is there any other way for me to figure out which I've got without pulling the shafts? It's a 2 DR, 5 Speed, if that means anything.
madXJ is offline   Reply With Quote
Glock Forum
