Rear axle in 91 XJ Laredo? - JeepForum.com
post #1 of 5 Old 08-15-2004, 01:19 PM Thread Starter
exc911ence
exc911ence's Avatar
I used to have a 91 XJ Laredo with the 4.0L HO engine and 5-speed tranny. I thought the rear axle was a Dana 35... am I wrong? Why I ask is that the guys on the TJ forum are always trashing the Dana 35 as being a weakling but if that's the axle I ran in the XJ, it took TONS of on and off-road abuse (including a trip to the dragstrip where I showed it no mercy) and never blew-up. So what's the deal? A Dana 35 in a 4-cylinder TJ will die the second it's off-roaded yet it withstands 190hp and power-shifting in a Cherokee?
exc911ence is offline
post #2 of 5 Old 08-15-2004, 05:41 PM
98XJ-ID
98XJ-ID's Avatar
with the tow package some older XJ's had the Dana 44. Newer XJ's have the D35 or the Corp 8.25, but I dont kno if they used the 8.25 in older Xj's
1990 Jeep Comanche Pioneer 4x4
4.0L - D30/D35 - 5-Speed - NP231- 130K
1998 Jeep Cherokee Classic 4x4
4.0L - D30/Corp 8.25 LSD - NV242 From a 2002 Grand Cherokee - 4" Suspension/31's - 136K
98XJ-ID is offline
post #3 of 5 Old 08-15-2004, 07:20 PM
AMK
AMK's Avatar
The D35 is a relatively weak axle, but you have to look at what you are comparing it to. There are a lot of TJs running 33s. The D35 isn't quite strong enough to handle a 33in tire when wheeling it hard, but it is plenty strong enough to handle stock sized tires.
The c-clips in the D35 are weak points as are the axle tubes in general. They are known to bend and crack -- which is why axle trusses are sometimes used.
YJ->donated; XJ->donated; XJ->in progress.
AMK is offline
post #4 of 5 Old 08-15-2004, 10:12 PM Thread Starter
exc911ence
exc911ence's Avatar
True, the average TJ would be running larger tires... I had 31x10.5-15s on my XJ and they looked huge but 31s look a tad small on the Wrangler...
post #5 of 5 Old 08-16-2004, 01:24 AM
isezumi00
isezumi00's Avatar
I think people over exaggerate the weakness of the D35 axle.
No, the D35 isnt going to hold up well against 33" super swampers and an ARB locker. Then again, that combo can snap a D44 too.
'91 XJ Laredo
Rustys 3" Coils Frankenleef rears||DT3000 shocks||JKS Quicker DQ
Optima Red Top||Mixin' match 31x10.5x15|| Rusty's HD Trac Bar
isezumi00 is offline
what should i do while i have my rear axle out? Teal2doorXJ XJ/MJ Cherokee Non-Technical Forum 7 08-07-2009 06:52 PM
body parts laredo vs laredo sport maddog-007 XJ Cherokee Technical Forum 2 02-03-2008 10:55 AM
Make rear axle freewheel - Bad Rear Diff - Drive in 4HI LR103 XJ Cherokee Technical Forum 12 11-01-2007 10:57 AM
95 Laredo Rear Hatch Problem ! sendit XJ Cherokee Technical Forum 1 05-28-2005 06:23 PM
Anyone know why my 90 laredo does not have a rear sway bar? twisted_ed XJ Cherokee Technical Forum 3 03-09-2005 04:41 PM
