Rear 4 link questions - JeepForum.com
post #1 of 16 Old 01-12-2010, 06:06 PM Thread Starter
Cobra03
1991 XJ Cherokee
I have a 91 XJ that i am wanting to do a custom rear 4 link with coils. what are the pros and cons of doing this over leaf springs. i want more articulation. pro. can i use 3in front lift springs in the rear for this project? anyone have any pics beside clayton offroads jeep? I dont like their setup.
Cobra03 is offline
post #2 of 16 Old 01-12-2010, 06:27 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Rock Krawler Catalog
xjfever is offline
post #3 of 16 Old 01-12-2010, 09:01 PM
RockRodHooligan
RockRodHooligan's Avatar
TNT has one of the best belly pans and rear coil/4 link on the market imho, not cheep, but well worth the extra clearance and strength you'd gain over other kits.
http://www.jeepforum.com/forum/f11/b...-coils-811707/
And Stock TJ rear coils will give you 5" of lift, so no, I would not recommend a 3" XJ front coil in the rear
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #4 of 16 Old 01-12-2010, 09:18 PM
Diamond-x
1991 XJ Cherokee
I agree with the above, 3" lift springs are far to short.
Most guys building custome 4-link are running coilovers with +10" of travel.
Diamond-x is offline
post #5 of 16 Old 01-14-2010, 12:59 AM Thread Starter
Cobra03
1991 XJ Cherokee
Originally Posted by xjfever View Post
i dont want to buy one i want to make it.
i like the way this was made. i was thinking on cutting into my rear frame rails and putting in a pocket. but i think i will just put the coil on the bottom of the frame.
91 XJ 12in custom long arm (still in the works)
35in pro comp mud terrains m/t classics L.A. from ironman4x4fab.com
Cobra03 is offline
post #6 of 16 Old 01-14-2010, 08:15 AM
RockRodHooligan
I had actually thought about getting the back two pieces of the belly pan(they bolt up to my existing belly pan), and rear cross member, then building the rest myself. TNT quoted me about $400 for the parts I wanted.
96 XJ:
***** inches...
post #7 of 16 Old 01-14-2010, 09:29 AM
wil badger
It's not coils but this is what I did with mine when I 4 linked it.
[Jeeps-Offroad Reader Rigs] :: Rear Coilover conversion
You might want to look into doing something with a rear swaybar. Yes you will gain droop in articulation but the price is body roll. The rear leaf springs help to stabilize the vehicle in off camber positions with coils the body will want to roll a bit more.
wil badger is offline
post #8 of 16 Old 05-17-2010, 01:29 AM
87jeepgw
1987 FSJ Wagoneer
with a triangulated 4 link you eliminate the need for a trac bar and sway bars
87jeepgw is offline
post #9 of 16 Old 05-17-2010, 01:37 AM
wil badger
Huh?. You are correct that a track bar wouldn't be needed but what is your thinking on the no swaybar? Being triangulated you would still need a swaybar to help stabilize body roll. Not to say you can get away without one. I didn't have one but it would have helped that's for sure.
post #10 of 16 Old 05-17-2010, 02:03 AM
87jeepgw
1987 FSJ Wagoneer
your right but for a trail rig its not necessary, as long as you dont go hauling around a corner its not a problem...but ive seen tri 4 links with minimal body roll...the higher it goes the more body roll you get, thats what ive found out haha
87jeepgw is offline
post #11 of 16 Old 05-17-2010, 02:21 AM
wil badger
Ya well being the driver of a linked truck I can tell you that you are pretty wrong on that one. Trying being off camber and lifting a tire, not a fun feeling.
post #12 of 16 Old 05-17-2010, 02:58 AM
87jeepgw
1987 FSJ Wagoneer
every rig handles different, my wrangler has a custom 4 link and is fine with out sway bars
87jeepgw is offline
post #13 of 16 Old 05-17-2010, 04:06 AM
wil badger
That's a completely different rig and can be made to have a lower CG. I'm talking about a rear swaybar. I never ran a front swaybar. I know that I would have run one on the rear but I kind of used the air bumps to get away with it. Like I said it can be done but with the right swaybar you won't even notice it while it's doing it's job. You will not lose an articulation by running the proper setup either. I used to be able to do everything from run around the West Desert at 90 or go crawling around in the rocks without issue but it would have been even smoother with a nice rear swaybar on it.
post #14 of 16 Old 05-17-2010, 07:01 AM
RockRodHooligan
Hey Will, is that a BTF rear truss?
And I totally agree with Will on a rear sway bar, though I will be running something like an Anti-Rock or ORO Sway-Lock when I 4-link the rear. I'll be putting one of the two up front once I get the new front axle and long arms on up front.
96 XJ:
***** inches...
post #15 of 16 Old 05-17-2010, 10:49 AM
wil badger
Ya that was BTF truss. Nothing to special if I were to do it again I would have just made my own truss that was separate of the cover.
Home Made Y-Link Questions Jeep450r XJ Cherokee Technical Forum 17 09-30-2009 03:15 PM
XJ Rear 4 Link DC4W-93XJ XJ Cherokee Technical Forum 1 06-21-2009 09:15 PM
questions for people with a RK 3 link to finish my 99 build jersey_jim XJ Cherokee Technical Forum 8 05-08-2009 09:30 PM
4-link rear? Matt1994XJ XJ Cherokee Technical Forum 1 03-30-2006 12:09 AM
rear 4 link question spaghettixj XJ Cherokee Technical Forum 5 10-29-2005 12:23 PM
